Scripting
 1-5  6-25  26-45  46-65  66-68
7238.26 In reply to 7238.25
Thank you Michael, I think I'm understanding more and more.
Your reply http://moi3d.com/forum/lmessages.php?webtag=MOI&msg=5461.10 helped me a lot understanding booleandiffrence. But if I run this script it looks fine at fist. But when I click on the resulting cylinder and move it, suddenly the result from the first booleandiffrence apears again.
Why is that?
7238.27 In reply to 7238.26
Hi dune1982,
> first booleandiffrence apears again. Why is that?
Hmmm, I don't know why that would happen. I tried running that script over here and I can't seem to get the reappearing behavior to happen when I move the booleaned cylinder result.
Maybe you're seeing the result of a history update, what happens if you select everything and run Edit > History > "Disable update" button before trying to move the object does that make any difference?
7238.28 In reply to 7238.27
Hello Michale
>Maybe you're seeing the result of a history update, what happens if you select everything and run Edit> History > "Disable update" button before trying to move the object does that make any difference?
Yes that helped after Disableing Update the result does not appear. What does that say now?
Thank you
7238.29 In reply to 7238.28
Hi dune1982,
I guess it says that the effect you saw was due to a history update - there is a mechanism in MoI where if you edit an object, if it was one of the inputs that were used to generate some other object in the current model, the command that created it is basically re-run for you and the outputs regenerated. This can sometimes cause unexpected results if pieces were moved so that they do not intersect one another at all or things like that.
7238.30
Hello
Everytime when I think: well now you know it. I seem to hit a script that I cant handle.
Today I'm trying to make a sweep:
var factory = moi.command.createFactory( 'sweep' );
factory.setInput( 0, triangle ); //is a objectList with three lines joined to a triangle
factory.setInput( 1, helix ); //is a objectList with a helix in it
factory.setInput( 2, ); //no idea what to set here
factory.setInput( 3, ); //no idea what to set here
factory.setInput( 4, 'none' );
factory.setInput( 5, 'flat' );
factory.setInput( 6, true );
factory.setInput( 7, true );
factory.setInput( 8, true );
// I stoped here as I have no and whant no scaling
factory.commit();
I only get a calculation failed out of this, i guess it is because auf 2 and 3 missing.
7238.31 In reply to 7238.30
Hi dune1982, here are the inputs for sweep:
0 : ObjectList - Profile curves.
1 : ObjectList - Rail curves.
2 : Orientation List - List of IMoiCurveOrientation objects for profiles, for history updates leave empty on first run.
3 : Orientation List - List of IMoiCurveOrientation objects for rails, for history updates leave empty on first run.
4 : String - Point end mode, one of: 'none', 'pointystart', 'pointyend', or 'pointystartandend'
5 : String - twist type - 'freeform' or 'flat'
6 : Boolean - Maintain height true = maintain height for two-rail sweep (stretch profiles instead of uniformly scale).
7 : Boolean - cap ends true = do planar end caps.
8 : Boolean - Maintain tangent - true = use tangent preserving sweep if possible.
9 : Object - scaling rail - If set this defines a scaling curve.
10: String - Profile synch type - Options for synchronizing profiles: Auto, Exact, Refit, or NumPoints.
11: Int - Number of points to use for profile numpoints synchronization mode.
12: Point - "Flat direction" - Direction vector for twist=flat mode.
If you're still stuck could you post a complete script that has the other pieces like your helix and triangle curve being generated so I can run it over here and see what's wrong?
7238.32 In reply to 7238.30
Pipe2 has some clues, and input 1 of factory.setInput( 1, WrapWithObjectList(rail) );
? Brian
7238.33
Thank you Michael but I'm still stuck,
Here is the whole code.
var length = 100;
var sradius = 28
var pitch = 5
factory = moi.command.createFactory( 'helix' );
var frame = moi.vectorMath.createFrame();
frame.origin = moi.vectorMath.createPoint( 0, 0, 0 );
factory.setInput( 0, frame);
factory.setInput( 1, moi.vectorMath.createPoint( 0, 0, length ));
factory.setInput( 2, moi.vectorMath.createPoint( 1, 0, 0 ));
factory.setInput( 3, sradius);
factory.setInput( 5, sradius);
factory.setInput( 7, steigung);
factory.setInput( 8, 'pitch');
factory.setInput( 9, false);
var helix = factory.getCreatedObjects();
factory.commit();
function drawLine(x1,z1,x2,z2)
var linefactory = moi.command.createFactory( "line" );
linefactory.setInput( 0, moi.vectorMath.createPoint( x1, 0, z1 ) );
linefactory.setInput( 1, moi.vectorMath.createPoint( x2, 0, z2 ) );
var objlist = linefactory.calculate();
var line = objlist.item(0);
moi.geometryDatabase.addObject( line );
return line;
var linelist = moi.geometryDatabase.createObjectList();
linelist.addObject(drawLine(sradius, -steigung/2, sradius, steigung/2));
linelist.addObject(drawLine(sradius, steigung/2, sradius+5, 0));
linelist.addObject(drawLine(sradius+5, 0, sradius, -steigung/2));
var factory = moi.command.createFactory( 'join' );
factory.setInput( 0, linelist );
var triangle = factory.getCreatedObjects();
factory.commit();
//erstellt sweep
factory.commit();
Thank you for all the help
7238.34 In reply to 7238.33
Hi dune1982, it seems that script there is not complete, I get an error:
ReferenceError: Can't find variable: steigung on line 13, is there some previous part of the script that is missing in your post?
Looking over your last calls to the sweep, the problem might be that you are specifying twist = "flat" but not providing the flat direction which is on input index 12 : Point - "Flat direction" - Direction vector for twist=flat mode.
But I can't tell for sure if that is why it's failing because I'm not able to run the script over here due to the variable named steigung missing from the script.
7238.35 In reply to 7238.34
Oh yes, my mistake,
just rename the variable pitch to steigung or the other way ;-)
7238.36 In reply to 7238.35
Hi dune1982 - the problem is that your triangle and helix object lists are empty. That's because the factory has not created anything yet at the time that you call factory.getCreatedObjects(). Insert a call to factory.update() before you call factory.getCreatedObjects() and that should fix up your script, here I've marked the added lines with >>> <<<<<:
var length = 100;
var sradius = 28
var steigung = 5
>>>>factory.update();<<<<
factory.commit();
return line;
factory.commit();
//erstellt sweep
factory.commit();
7238.37 In reply to 7238.29
Hello Michael, we have talked about this before. But now as my script is getting bigger, the history or whatever seems to be makeing funny things. Is there a way to turn this off? I have cylinders and booleanunions and other things in my script. After running it I have some of the things twice on the screen and now they wont dissapear when I do something new.
7238.38 In reply to 7238.37
Hi dune1982,
re: turning off history - there is a property on objects that controls whether they will be a part of history updates or not. You can set it manually by selecting the objects and running Edit > History > "Disable update" button.
You can set it through your script by changing the .updateWithHistory property that's available on an geometry database object.
If you have a single object, set: obj.updateWithHistory = false;
If you have an object list, use: objlist.setProperty( 'updateWithHistory', false );
That will then have the same effect as running Edit > History > "Disable update".
7238.39
As I'm learning more and more I always meet a function which doesn't work like I think it would.
Today I tried to do a booleanunion on two cylinders. I get a typeerror, but why and how can I make it better?
var cylinders = moi.geometryDatabase.createObjectList();
/*make cylinder 1*/
frame = moi.vectorMath.createTopFrame();
factory = moi.command.createFactory( 'cylinder' );
factory.setInput( 1, frame );
factory.setInput( 3, 30 );
factory.setInput( 4, moi.vectorMath.createPoint( 0, 0, 60 ) );
factory.update();
var cyl1 = factory.getCreatedObjects();
factory.commit();
cylinders.addObject(cyl1);
/*make cylinder 2*/
factory.setInput( 3, 60 );
factory.setInput( 4, moi.vectorMath.createPoint( 0, 0, 30 ) );
factory.update();
var cyl2 = factory.getCreatedObjects();
factory.commit();
cylinders.addObject(cyl2);
/*cyl1 plus cyl2*/
moi.geometryDatabase.deselectAll();
factory = moi.command.createFactory( 'booleanunion' );
factory.setInput( 0, cylinders );
factory.update();
factory.commit();
Thanks for all the help so far
7238.40 In reply to 7238.39
I don't get a type error. My MoI on OS X crashes when I run your latest script.
7238.41 In reply to 7238.39
7238.42 In reply to 7238.39
Hi dune1982,
It's due to this type of sequence here:
factory.commit();
The variable cyl1 contains an object list, which is what factory.getCreatedObjects() returns back.
Then later on the call to cylinders.addObject() is expecting an individual object to be passed to it, but instead you are passing that object list.
There does not happen to currently be a method on object lists to combine another list with it, you'll need to make a helper function like:
function CombineLists( targetlist, fromlist )
for ( var i = 0; i < fromlist.length; ++i )
targetlist.addObject( fromlist.item(i) );
and then call that function to combine the lists together.
7238.43 In reply to 7238.42
Ok I will try it with the fuction. But isn't there a return blabla missing in the function?
But isn't there a way to add an object to a list. In this case if var cyl1 = factory.getCreatedObjects(); creates the objectlist cyl1 so I could just add the next cylinder to the list cyl1
In my mind i would do cyl1.addObject(factory.getCreatedObjects()); in the factory for the next cylinder, but then I would add a list to a list which is not possible.
I made it this way now, as there are only two objects
/*make cylinder 1*/
factory.update();
factory.commit();
/*make cylinder 2*/
factory.update();
factory.commit();
cyl1.addObject( cyl1.item(0) );
/*cyl1 plus cyl2*/
factory.setInput( 0, cyl1 );
factory.update();
factory.commit();
EDITED: 5 May 2015 by DUNE1982
7238.44 In reply to 7238.43
Hi dune1982
Functions don't always have to return a value if they are written to just operate on the parameters that are passed to them which is what that little function is set up for.
Yes that would work too.
Unfortunately the way you want to do it here won't work because the addObject() method only expects to receive an individual object, and you are instead passing it an object list here. In the future I would like to improve this to make things more flexible, like maybe having an .add() method that could take either an individual object or an object list, but that's not how it is set up at the moment though.
7238.45 In reply to 7238.44
Hello Michael,
the script with the two cylinders is working now.
Now I want the user to set a value for the diamter of the first cylinder.
I replace the value 30 of factory.setInput( 3, 30 ); by a variable lets say diameter.
Then I tried the javascript thing prompt in that way:
var diameter = prompt("Please enter a value", "10");
But nothing happens with prompt, no dialog opens nothing. Does MoI use a different command, or how to I let the user set a value?
I tried to find the answer in existing scripts but, so far found nothing.
Show messages:  1-5  6-25  26-45  46-65  66-68
