Hi Chipp,
Thanks for responding.
The user i mention is Samuel Zeller and his post is from Fev 2014.
His UI redesign is quite slick and the icons are simple and effective. A few users jump in and ask if he would share that UI.
Anyway, you made a fine job, and is good news for those who are affraid of messing with Moi css.
Take your time, finish it at your will, and i will be in line to use it : ) as it is right now, even without the icons swap.
Thanks again for your work.
Carlos
I've added just about all the CSS. Still have problems locating a couple things (other thread started to figure that out).
You can now save and load settings. Sorry, you won't be able to just *load* a moi.css file and parse it, but you CAN save your changes and load them later for tweaking. There's now a prefs file which currently only stores the moi.css directory.
I need to do a bit of tweaking to get it to be PC compatible, but I should be able to release something by tomorrow evening.
Here's what I've got so far:
UPDATE: Fixed the last two remaining issues (I'm sure there will be others once testing starts).
Here's a clown pass to check to make sure all is working correctly. First the app:
