Hi blindfoldjump,
> 1. In the documentation I found something called Variable Fillet. However I can seem to be able
> to activate this in the Trial version I use, is it disabled?
It's enabled in the v3 trial version, you need to set up a new fillet set and pick some points on the edges to define the locations for where to use the alternate fillet radius, there's an example video here:
https://www.youtube.com/watch?v=CemIL-wleOw
Also see here for some written explanation of what the video is showing:
http://moi3d.com/forum/index.php?webtag=MOI&msg=7178.2
> 2. About ViaCAD. I found that alot of people have been writing about 'Autodesk 123d'.
> From what I understand it a free software and by the looks of, at least this video below
> it seems it does a pretty good job filleting. Is ViaCAD to prefer before Autodesk 123d ?
Yeah it's another good choice - I can't remember if there are some special limits to the free version like "not for commercial use" or limited file format import support or things like that.
It's certainly looking into as well.
