MOI 64 bit please!!
7228.1
Hi there,
MOI is from my point of view the best soft to convert files from CAD to polygons.
I use it a lot but I could use it a lot more if I could use all my memory for that (44 gigas).
Yes, I have some big machines to convert and it uses a lot of ressources for that.
The only limitation is apparently this 32 bit mode, do you think the next version will switch to 64 bit, Michael?
Thanx for your answer or advices,
Arnaud
7228.2 In reply to 7228.1
Hi Arnaud, I am looking into it but there will be a lot of work involved and so it's too early yet to say for sure if the next version will be 64-bit or not as of yet.
In the meantime there are some settings you can adjust that will make MoI consume less memory and can help for larger models, see this previous post for some tips on that:
http://moi3d.com/forum/index.php?webtag=MOI&msg=5322.2
7228.3
I would agree with this comment.
I know we have had this discussion before but i feel its a major stumbling block now. I use MOI extensively but all too often the 32bit limitation rears its head. Initially the problem of working with large models and having to export in groups - a bit of a pain. However I now find that the export to ai/pdf with the line thicknesses is also restricted due to 32bit - don't get me wrong this feature is amazing, however with any models of complexity it just can't handle it. I always get a memory full message and so have to use my Arbortext CADprocess to export.
I know its a big job to convert but it seems to me the 32 bit achilles heel will only become more common as we move swiftly forwards into the future with ever more complex models and fancy tricks to create them. I am also interested in the instances feature many seem to want (me too) is this also something which could be limited if its still in MOI 32bit?
To end on a happy note MOI is still at the top of the league for creating my 3D objects, exporting with great meshes and converting and modifying STEP files from CAD software :-)
Matt
7228.4
+1 here Michael. MoI is now my main 3D application. I often import large files built in AD Inventor but often, the objects I create from scratch within MoI overrun memory - especially when exporting them in a polygonal format to MODO for detail work and rendering. The work around is to export the file in sections but this is obviously not ideal.
M :-)
