Nudge + Set position
All  1-2  3-6
7226.3 In reply to 7226.2
Thanks Michael, that cleared up everything. Flat snap - very handy!
7226.4 In reply to 7226.3
One followup question on the Nudge:
I felt that the Nudge was quite alot to big so added the "small" to the command line.
However I still feel its a too big jump, is it possible to change the command line to even smaller nudge? I would like it to be 1/10.
7226.5 In reply to 7226.4
Hi blindfoldjump, which specific nudge script did you end up using? There are a couple of different ones.
The initial one should be already doing a 1/10 unit nudge for the "small" variant I think. If yours is behaving differently than that could you maybe post the particular Nudge script you are using here so I can take a look?
The nudge amounts will be in the Nudge.js file, and if you want to change the behavior you could edit the script in a text editor to get whatever distances you would specifically like.
7226.6 In reply to 7226.5
Heya
I tried both of them which were in the url you linked to. They seemed to nudge the same distance.
Im gonna try to edit the .js file and see if I can get that to work.
Cheers!
Show messages: All  1-2  3-6
