Convert edge -> Curve
All  1  2-7
7224.2 In reply to 7224.1
Yes if i good understand the question that is not sure! :)
Put an image of wished is always better!
http://moi3d.com/forum/messages.php?webtag=MOI&msg=5136.1
7224.3 In reply to 7224.1
Hi blindfoldjump,
> Is it possible to pick an edge of a surface and then straight up convert(+duplicate) it to a curve?
Select the edge you want to duplicate, then use Copy / Paste, either by the buttons on the Edit palette, or just by Ctrl+C Ctrl+V shortcut keys.
When you use Ctrl+C to copy an edge it is copied as a regular independent curve object so that's what you'll have when you paste it in. After the paste the duplicated curve will be selected.
One thing to watch for - some commands like Fillets work on edge selections and if you have some separate curves stacked up right on top of edges it can then be difficult to select the edge. In a situation like that you need to select the curve and hide or delete it before you'll be able to select the edge very easily. Curves have selection priority over edges so when there are 2 stacked up it will be the curve that will usually be targeted by your click.
7224.4 In reply to 7224.2
Thank you frenchy.
But actually what I wanted was something even more simple.
However I just figured it out. I just picked an edge - and Ctrl-C Ctrl-V - and new curve created from edge.
Just amazed how intuitive Moi is! Such a great software!
7224.5 In reply to 7224.4
Michael:
Figured it out just before you posted :)
Thanks for answering Michael, also thanks for creating such a great product. After just a couple of days of trying it out Im already freestyle designing, its a great feeling!
7224.6 In reply to 7224.5
Hi blindfoldjump, I'm glad that you are liking MoI and getting in the groove with it already!
7224.7
Another option is to select the edges, and use the join command... gives a joined curve, so it is one less command that you have to do.
edit: it only works when you have more than 1 edge selected though. ;)
EDITED: 3 Feb 2015 by TALLEMAN
Show messages: All  1  2-7
