Cycles for MoI
 1-4  …  25-44  45-64  65-84  85-104  105-113
7208.65
I had another problem in the beginning as well.
The "Orientation" for the OBJ export was set to Z-Up.
Eventually figured out that it should be set to Y-Up.
scott
7208.66 In reply to 7208.65
Hi Scott,
I forgot about this MoI setting :) Thank you.
Fixed.
EDITED: 7 Mar 2022 by SMIRNOV
7208.67 In reply to 7208.66
No problem Max.
Thank you.
7208.68
hi... i am not able to download "Cycles Standalone", anybody know where i can find it?
7208.69 In reply to 7208.68
http://moi.maxsm.net/media/files/Cycles.CPU.zip
http://moi.maxsm.net/media/files/Cycles.CUDA.zip
At this moment cpu version is more stable.
Cuda version has some problem with file saving. Waiting for update.
7208.70 In reply to 7208.69
7208.71 In reply to 7208.63
I realize that what I offer here is not a solution, but might something like this help to avoid jumping into the problems with parallel mode?
var vp = moi.ui.mainWindow.viewpanel.getViewport('3D');
if (vp.projection != 'Perspective')
vp.projection = 'Perspective';
moi.ui.alert('Projection set to "Perspective".');
return;
Might there be someway of asking the user for permission before switching the projection setting?
7208.72 In reply to 7208.71
Hi Mindset,
I'm not sure how that would be done - there are multiple ways for it to get set, one of which is opening a file that had it set that way when it was saved... It would be difficult for a script to try and get involved with that since it happens right in the middle of the open process.
7208.73 In reply to 7208.72
What a terrific software and community!!!
However, regarding message 7208.72 in reply to 7208.71, it is not clear what is opening...
Message 7208.71 was intended as inquiry about the Cycles script by Max Smirnov.
// Cycles v.0.98 - Max Smirnov. 2015
function Cycles()
var param = moi.command.getCommandLineParams(), exp=(param =='noexport')?false:true;
// Add this Block?
return;
// END Add this Block?
if ( param =='reset') { moi.ui.commandUI.resetPaths(); }
moi.ui.commandUI.Cycles(exp);
Cycles();
Seems the loink of the Standalone Cycles 64 bytes is not more accessible! ???
http://blender.dingto.org/cycles_standalone/Cycles_Windows64.zip
Someone has again this file on his computer ? Cycles_Windows64.zip
Thanks by advance! Because this process here is too hard for me!
http://wiki.blender.org/index.php/Dev:2.6/Source/Render/Cycles/Standalone
EDITED: 2 Apr 2015 by PILOU
7208.76 In reply to 7208.75
EDITED: 2 Apr 2015 by BEMFARMER
7208.77 In reply to 7208.76
Many Thanks!
7208.78
Cycles CUDA --> le fichier est corrompu :(
Si qqn a une version fonctionnelle ca m'interesse
Phil
7208.79 In reply to 7208.78
J'avais récupéré une version fonctionnelle sur le site de Pilou : http://moiscript.weebly.com/cycles-pour-moi.html
Bear17
7208.80
Hi Max,
I've noticed from forum that you use Octan for rendering.
Don't you have similar script like MoI/Cyclec for Octan users by chance? :-)
(http://render.otoy.com/forum/viewtopic.php?f=73&t=44688)
All good to you.
Mik
7208.81 In reply to 7208.80
Hi Mik
Sorry, I didn't write such a script. I prefer to import obj manually.
The only script I wrote for Octane render is MoI scatter tool.
http://moi3d.com/forum/index.php?webtag=MOI&msg=6486.20
7208.82
Thanks a lot, Max!
I import obj into Octane manually as well of course, no problem with it.
It was only idea to have some fusion of these great softwares :-)
Mik
7208.83
Hi Max, I've just picked up this tread on the blog. Thanks.
I have installed the latest versions of Cycles and the script and all works fine and Cycles opens on running the _cycles script. The Cycles window is grey and blank but cycles is running. I have set the 3D view to 'perspective' and read the whole blog and cannot see a solution for this problem.
I am using a MS Surface Book on Windows 10.
7208.84 In reply to 7208.83
Hi Matt
Are you using software or gpu cycles version?
Try this one: http://moi.maxsm.net/media/files/Cycles.CPU.zip
Show messages:  1-4  5-24  25-44  45-64  65-84  85-104  105-113
