Cycles for MoI
 1-15  16-35  36-55  56-75  …  96-113
7208.16
First public release of Cycles for MoI script
Installation:
- extract script archive into the MoI/commands directory
- download Cycles standalone (http://blender.dingto.org/cycles_standalone/Cycles_Windows64.zip) and extract it into MoI/cycles directory
- create MoI/snapshots directory
Script usage:
_Cycles -> export selected objects as cycles xml files, start Cycles
_Cycles noexport -> If you exported scene objects once, you don't need to export it every time when you run Cycles. This mode useful while changing camera position or material settings.
Materials:
Default material - Diffuse, Rougness 80%
You can change the material by editing the style name
Examples:
[D:20] = Diffuse, Rougness 20%
[G:20] = Glossy, Rougness 20%
[S:10] = Glass, Rougness 10%
[E:1000]= Emission, Strength 1000
Cycles hotkeys:
P - pause
Q - save image and quit
I - interactive mode
EDITED: 7 Mar 2022 by SMIRNOV
A futur hit!
Prodigious! Don't know that Cycles existing as Stanalone! (So no need to learn Blender! :D
Ah damned : don't works for me!
Just appear and disapear the Cycles Windows! (1/10 second ! ;)
No problem that Moi is in the (x86) folder and Cycles who seems a 64 bits program is inside this Moi's folder ?
What exactly the process ?
I launch Moi - I export an object as .xml ??? i have not that inside Moi !
I launch Cycles (?)
or other... ?
...must I install the last version of Blender too?
EDITED: 6 Feb 2015 by PILOU
7208.18 In reply to 7208.17
anyway it should works.
Does export window appears?
No, just install cycles standalone.
My script can have problems with special characters in the paths.. I'll check it tomorrow.
7208.19 In reply to 7208.18
Just a Dos (?) window as I can see on this rapid view! :) and just 1/10 second then nothing!
What must be there in the Moi's Cycles folder ? All the unzip Cycles file ?
Ps It's a Zenit camera ? :)
http://wiki.blender.org/index.php/Dev:2.6/Source/Render/Cycles/Standalone
<< Cycles needs to be started from a terminal: cycles [options] file.xml
How have this terminal ?>> My script can have problems with special characters in the paths
(sure French Windows System alas has some accents... :)
Where is your script ???
I don't see it in your post!!!
http://moi3d.com/forum/index.php?webtag=MOI&msg=7208.16
7208.21 In reply to 7208.20
Cycles.v.0.8.2015.02.06.zip -> moi directory/commands
Cycles_Windows64.zip -> moi directory/cycles
Yes :-) My first slr.
7208.22 In reply to 7208.20
Hi, it's working very nicely. The exporter seems very stable and quick. Is there others options for materials?
Cool!
All works this time!
7208.24 In reply to 7208.23
Frenchy Pilou what them you use for Windows? I saw that kind of windows before and I like them.
My Portfolio: www.samardac.com
A lot of my Tutorials!
Subscribe to my youtube channel: http://www.youtube.com/samardac
Russian community of MOI 3D: www.vk.com/moi3d
No Special Windows, it's the natural model by default in Windows 8! :)
(i just edit the color of 2D image for the forum ;)
But you can make the same inside Moi with editing color of the UI !
Options / View
French version and manual of Cycles for Moi
http://moiscript.weebly.com/cycles-pour-moi.html
EDITED: 7 Feb 2015 by PILOU
7208.26 In reply to 7208.25
Frenchy Pilou, I just talking about windows theme, not about MoI GUI, now I understood it is Windows 8, thanks.
7208.27 In reply to 7208.16
Does anyone know if this works with the Mac?
7208.28 In reply to 7208.27
From this http://wiki.blender.org/index.php/Dev:2.6/Source/Render/Cycles/Standalone
I suppose yes, but the Max script itself I don't know!
Seems the render Window size is not kept if this size modified at the beginning for the next renders!
7208.30
New version.
Shaders support:
[D:xx] - Diffuse : Roughness 0-100
[G:xx] - Glossy : Roughness 0-100
[S:xx] - Glass : Roughness 0-100
[V:xx] - Velvet : Sigma 0-..
[C:xx] - Toon : Smooth 0-100
[T] - Translucent
[E:xx:xx] - Emission : Strength 0-... : Size (for point light sources; optional)
Added mix shader:
[G:10 C:30] - Glossy:10+Toon:30 (50/50 default)
[G:10 C:30 70] - Glossy:10+Toon:30 (30/70)
7208.31 In reply to 7208.20
It's possible to do the same for mac ?
7208.32
Added:
[A] - Ambient occlusion
fixed point lights export bug
Finema
chippwalters
Unfortunately I don't have a Mac, so I can't check this.
I'll try to install MacOS to virtual machine.
It's impossible to get window size information from cycles to moi.
7208.33 In reply to 7208.32
<< It's impossible to get window size information from cycles to moi.
I speek about the Window's size render of Cycles: who can be anywhere on the same monitor or on another one
so not in the screen of Moi !
7208.34
OSX:
I managed to get Cycles standalone running on OSX, also managed to write out an .xml file into the temp folder with your script!
Then with Terminal, I rendered it with Cycles. With this script:
/Applications/MoI\ v3.app/Contents/Resources/drive_c/moi/cycles/cycles /Applications/MoI\ v3.app/Contents/Resources/drive_c/users/Wineskin/Temp/ball_square_scene.xml
But not a programmer, so didn't understand how to edit your script so it does this automatically.
http://blender.dingto.org/cycles_standalone/Cycles_OSX_10.9_x86_64.zip
EDITED: 8 Feb 2015 by FAKEPILOT
7208.35 In reply to 7208.34
When you say that
"Then with Terminal"
How do you process for access to a "terminal" ?
Show messages:  1-15  16-35  36-55  56-75  76-95  96-113
