Cycles for MoI
 1-20  …  61-80  81-100  101-113
7208.101 In reply to 7208.100
Hi David, I just tested downloading http://moi.maxsm.net/media/files/Cycles.CPU.zip and it seemed to be fine over here. Did you get a message when trying to unzip it that the archive is corrupted, or was it some other error? I'd recommend deleting it and trying to download it again.
7208.102 In reply to 7208.98
Hi Max.
I downloaded http://moi.maxsm.net/media/files/Cycles.CPU.zip, But the file is corrupt. Can you upload it again?
EDITED: 17 Apr 2018 by YUAN
7208.103
Very sad, this was not more developed, this was the best free option rendering engine for Moi3D if developed.. Is old 5 years..
7208.104
Hello!
I let myself be seduced and wanted to try cycles. Unfortunately nothing worked. Even though I made a backup of all moi files I played back, I can still use the snapshot function of Max Smirnov in custom ui (Moi V3), but the *.png images are not saved in snapshots anymore. Can anyone help what could be the reason for this?
--> have already discovered the bug. snapshots was no longer released, don't know why - did windows want me not to come to bed again (night work)?
(The folder snapshots was changed to read-only, that must be changed back again to writeable.)
Franz
EDITED: 15 May 2020 by FRANZ
7208.105 In reply to 7208.104
Hi Franz,
First of all, your operating system must be 64-bit, not 32-bit, because Cycles is a 64-bit program, it cannot run on a 32-bit system. Then, according to the method described by Max Smirnov (SMIRNOV), put the Cycles related files into the corresponding directory. The following is the effect I run through Wine under Slax (linux), MoI version V3 looks pretty good. If you use the Windows operating system, it will be easier to run.
7208.106
Hi Yuan and all!
Thanks for the help. I must have had an error in the installation before.
Now cycles runs, but I can't figure out how to set the output size. My rendering result I get is very small.
Please again for a hint.
Thanks a lot
Franz
For the test i used first.3dm from
http://moi3d.com/forum/index.php?webtag=MOI&msg=7208.16
7208.107
Hi!
First post here :-).
If anyone still wants to use the cycles port the zip-file actually can be extracted. Windows cannot on its own but 7-zip (open source) extract the files without any problems. Im running Moi V4.
I can't figure out how to update cycles when shifting camera view. The script doesn't seem to be the same as described on page 1. Also I wonder how to make materials more metal like as some of peoples screen shot shows.
Anyway Happy New Year
7208.108 In reply to 7208.107
Maybe this can help you ;)
https://www.blenderguru.com/articles/cycles-shader-encyclopedia
Good luck for find that you want!
EDITED: 1 Jan 2021 by PILOU
7208.109 In reply to 7208.108
Thanks I understand :-). I just don't know where to edit the materials. In the styles panel in Moi there is only an option to choose color.
7208.110 In reply to 7208.109
I am affraid that you must enter something like that inside Styles!
not enough friendly for me - i prefer all ready made! :)
Sorry in French
https://moiscript.weebly.com/cycles-pour-moi.html
Shaders disponibles
[D:20] = Diffuse: Roughness 20% par défaut (0-100)
[G:20] = Glossy: Roughness 20% par défaut (0-100)
[S:10] = Glass: Roughness 10% par défaut (0-100)
[E:1000]= Emission: Force 1000 par défaut (0-...)
[V:100] = Velvet par défaut: Sigma (0-...)
[C:xx] - Toon : Smooth 0-100
[T] - Translucent
[A] - Ambient occlusion
[TR] - transparent shader
[CH] - checker texture
Shader Mixtes
[E:xx:xx] - Emission : Puissance (0-...) : Size (Spot; optional)
[G:10 C:30] - Glossy:10 + Toon:30 (50/50 defaut)
[G:10 C:30 70] - Glossy:10 + Toon:30 (30/70)
7208.111 In reply to 7208.110
Thanks. Its strange that I cant find any way to imitate that screen shot with 5 visible colors. I can only get one at a time.
I really understand and agree why you prefer to not create materials like that :-D.
By the way I really like your thread "Funny thing at the opposite of Moi ;)". I also love to discover new programs and possibilities for making 3D-art, Music, Math and everything in between. I have the thread as a reference if I want to dig deeper into something.
7208.112 In reply to 7208.111
I have not relaunched Cycles for Moi but i can't understand your problem!
You can have normally any number of Styles...
(I have of course writed anything! :) must be of course something like Orange[D:20] etc...
7208.113 In reply to 7208.112
Ah thanks. Now I finally get it. I tried it and it works. I thought there was a place to choose theese values from a menu/popup box. I didnt realise that I actually had to write it myself directly in the name of the style. I read the first post again and the values are simply just put in manually.
Show messages:  1-20  …  41-60  61-80  81-100  101-113
