Is there a script to hide all named objects?
All  1-4  5-6
7205.5 In reply to 7205.1
Hi Chipp - also another way to do what you were looking for just occurred to me.
You can select named objects by typing in their names in the X/Y/Z input control, and you can wildcards in the name like for example typing in *wheel would select anything anything with a name that ends with "wheel", and if you just put in plain * there that will match all named objects.
So another way is to type the tab key (which puts focus in the X/Y/Z input control), then type * and push Enter, now all named objects are selected and you can hide them using Edit > Hide.
7205.6 In reply to 7205.5
Wow. Didn't know you could do that. Thanks for sharing. I prefer the script, but will use this as a way to select ALL common parts-- sorta like a cheap man's hierarchy tool where you can name each set of parts with a prefix and then select the correct groups.
I was wanting to create a mannequin for positioning in MoI but didn't have a good way to control easily many groups at once. This technique should do the trick!
Show messages: All  1-4  5-6
