Is there a script to hide all named objects?
All  1  2-6
7205.2 In reply to 7205.1
Hi Chipp, try putting this on a shortcut key:
script: /* Hide all named objects */ var objs = moi.geometryDatabase.getObjects(); for ( var i = 0; i < objs.length; ++i ) { var obj = objs.item(i); if ( obj.name != '' ) obj.hidden = true; }
7205.3 In reply to 7205.2
Thanks so much Michael! HUGE help :-) I'm working on this med drone and the objects list are getting so large!
A preview...
7205.4 In reply to 7205.3
Hi Chipp, you're welcome - wow that drone is turning out great!
7205.5 In reply to 7205.1
Hi Chipp - also another way to do what you were looking for just occurred to me.
You can select named objects by typing in their names in the X/Y/Z input control, and you can wildcards in the name like for example typing in *wheel would select anything anything with a name that ends with "wheel", and if you just put in plain * there that will match all named objects.
So another way is to type the tab key (which puts focus in the X/Y/Z input control), then type * and push Enter, now all named objects are selected and you can hide them using Edit > Hide.
7205.6 In reply to 7205.5
Wow. Didn't know you could do that. Thanks for sharing. I prefer the script, but will use this as a way to select ALL common parts-- sorta like a cheap man's hierarchy tool where you can name each set of parts with a prefix and then select the correct groups.
I was wanting to create a mannequin for positioning in MoI but didn't have a good way to control easily many groups at once. This technique should do the trick!
Show messages: All  1  2-6
