I know you do array along path curve but would it be possible to do slide along path curve ? What I mean is to to put an object (for instance a setting cutter) on a curve that has been projected onto a surface and then slide copies of it along the curve, pulling them out one after the other, so that they could be spaced unevenly as you choose along the curve , but still with the freeform arrangement that array gives you .
Kind of like a sliding snap but still with alignment staying the same relative to the surface.
I don't know if I am asking the impossible , but if MOI can do freeform array along a curve so easily I thought maybe it could do more:)
regards Tim.
