Custom Interface: Need same help to install addon
7187.1
Hello everyone!
This is my problem: I do not know how to install in MoI3D CustomUI.1.03. addon for windows. Kindly can anyone tell me how to do it? I've already downloaded from the forum the zipped folder. A small step by step guide would be very helpful. Thanks in advance for your help.
EDITED: 18 Jan 2015 by NINNO
7187.2 In reply to 7187.1
You must unzip the file then
Seems all is explain here ? Scroll the post 1 !
http://moi3d.com/forum/index.php?webtag=MOI&msg=6507.1
EDITED: 18 Jan 2015 by PILOU
7187.3 In reply to 7187.1
Hi Ninno - the steps for installing the CustomUI is to unzip the downloaded files, and then copy the unzipped contents into the MoI install folder under C:\Program Files (x86)\MoI 3.0
It's probably best to unzip it somewhere else to start with, like onto your desktop and then use Drag/drop to move the unzipped files over into C:\Program Files (x86)\MoI 3.0 . There will be one already existing file that will be overwritten inside the \ui sub-folder. If you don't get a prompt asking you about overwriting a file named CommandBar.htm then it means you did not drop the stuff into the correct folder.
Once you have done the drag/drop there will be some new folders "objects" and "snapshots" alongside the previously existing folders for "commands", "docs", and "ui".
If you try to unzip it directly into the MoI install folder, that can be problematic because by default Windows will prevent programs from modifying things inside of the program files folder. It's easiest to do that from Windows explorer since it will ask you for permission on demand and you can say yes then. If you run an unzipping program it will just probably silently fail to unzip into c:\Program Files unless you happened to start it initially with admin privileges.
7187.4 In reply to 7187.3
Hi Michael!
I did it!
Thank a lot for your help. It wasn't so difficult at the end.
I'm a new entry in this forum and i am trying to learn this fantastic software.
I did follow the link from Pilou....really exhaustive! I'm gonna to thank him.
Greetings from Italy
--Marco (Ninno)
7187.5 In reply to 7187.2
Hi Pilou
Thank you very much for the link .... Really useful. I'll keep it in my hard disk...You never know
I guess that you know well this software.
Anyway, could I ask you where I can find the Dino's plugin to have the Lighting Options?
I really would like to install it!
Thank you
--(Ninno)--
7187.6 In reply to 7187.5
I believe that is here! ;)
http://moi3d.com/forum/index.php?webtag=MOI&msg=5222.48
If you read French tones of marvelous infos are existing about Moi here ! ;)
http://moiscript.weebly.com/
7187.7 In reply to 7187.6
Hip Hip HurrĂ !!
I've done it!
Thank you soo much!.....You know i feel better.
I really enjoyed the link you posted, the site seems very interesting, i'll also put it in my favorites.
No I'm sorry I don't speak French, but don't worry there's always Google translator.
Ciao Pilou
in the future I'd like to stay in touch if ever I had some doubts.....Do you mind?
Have a nice day!
--(Ninno)--
