mac start up issue
All  1-2  3-8
7185.3 In reply to 7185.1
Hi Alan, usually a reboot should get you with a clean starting point and would normally also solve any stray running processes that are potentially gumming things up.
I guess try another reboot and try running MoI v3 first hand then without trying to run v2.52 first maybe.
7185.4 In reply to 7185.1
Hello! I downloaded the V3 trial to test on a Mac Mini with OSX 10.10 and am also seeing this issue that the program will not start... but if I end the wineskin processes I can get it to run again. I've been looking for a nice 3D design tool to use in a junior high school lab of Macs and am hoping this is the one, but this issue is a killer for that.
7185.5 In reply to 7185.4
Hi Ryan, unfortunately I haven't been able to figure out what causes that startup problem yet. If you reboot the machine does it seem to behave better after the reboot or not?
7185.6 In reply to 7185.5
Thanks for the reply! I've tried to isolate a reproducible problem and think I've found it. Whenever I minimize the program, my mac desktop / finder crashes and sends me to the login screen. When I log back in, the program won't run until I kill the wineskin processes. A full reboot also allows the program to run until I attempt to minimize it again.
7185.7 In reply to 7185.6
Hi Ryan, do you possibly see any different behavior if you change the operating system setting as described here? :
http://moi3d.com/forum/index.php?webtag=MOI&msg=6866.2
7185.8 In reply to 7185.7
Michael,
I do have a three-monitor setup using HDMI, DisplayPort and StarTech USB32DVIPRO. I turned off the separate spaces feature on OSX and rebooted my machine. The issue persisted when I attempted to minimize the MOI application. Thanks for the followup again!
Show messages: All  1-2  3-8
