V3: variable fillet and auto boolean
All  1-2  3-5
In French but very visual :)
7178.4
Thank you Michael and Frenchy! I got it now.
Extrude: In the demo video I thought I saw you select face and "extend" without have to back the extrude button each time.
Fillet: I've never done the two point click to create a fillet amount. I enter a value. I think this what threw me off while watching the demo vid.
I understand this now. Thanks again Michael for making this awesome software!
-Alano
7178.5 In reply to 7178.4
Hi Alano,
Yup, that was happening - when you see the additional extends I was running the Extrude command again each time, activating it by a right-click inside of the viewport.
If you right-click inside of a viewport when you are in selection mode, it will repeat the last run command, so if you want to run the same command several times in sequence you can right-click inside of a viewport when the command is finished to start it up again rather than going to the button each time.
Show messages: All  1-2  3-5
