Voronoi Script or plugin
 1-3  …  44-63  64-83  84-103  104-123  124-143  …  184-198
7177.84
almost perfect! the last issue is sharp corners even when smooth is 100%
7177.85 In reply to 7177.84
it's actually no issue... MoI has all the tools to get the desired results.
You can't expect that a script always does all the work for you!
7177.86 In reply to 7177.85
Hi Stefan!
@You : "...You can't expect that a script always does all the work for you!..."
I completely agree :)
The "manual stage" it's always necessary and, I would say, mandatory.
I agree.
Hi Marco,
7177.88 In reply to 7177.86
years ago I drawn Voronoi with ballpen. so, you can't blame me - I already made a lot of "manual stage" and I can't see any problems if script makes a same job in better way.
Nobody is blaming you, even if it may sounded like that.
Like i said, i would not expect that a script does always everything for me
and i know also that i can't put in here permanent requests to programmers
to add this and that in their free scripts, in their spare time. Be happy what
you have and since you know how to do it manually, simply do it. :-)
7177.90 In reply to 7177.89
now you're teaching me...
Hello moiers :)
...here's another "had fun with voronoi"!
This time...Moi + 3D-Coat (voxelize and built-in renderer)
"Voronoi jail" :)
Ciao!
Marco (mkdm)
EDITED: 6 Mar 2018 by MKDM
Hello everyone!
...another "had fun with Voronoi"
....Thanks a lot Max :)
This time : Moi3D + Rocket3F + Affinity Photo
Ciao!
Marco (mkdm)
Hi Marco,
nice images! However i have a little suggestions, which Pilou also made once, if i remember correctly.
Is it possible that in the future you post smaller images (and your large ones in the gallery maybe)
because it takes quite a bit time to load the pages and auto resizing them. Zarkow, for example,
does this also now, with his images. Maybe look at Zarkow's images, as an example, to get the
max size for displaying images here, without resizing.
7177.94 In reply to 7177.93
Hello Stefan!
@You : "...Is it possible that in the future you post smaller images (and your large ones in the gallery maybe) because it takes quite a bit time to load the pages and auto resizing them..."
I will certainly do it !!! :)
I apologize for the inconvenience...I forgot to do so.
Thanks for the reminder :)
Thank you Marco,
much appreciated!
7177.96 In reply to 7177.95
...Done :)
I've changed my latest 3 images that I have uploaded here (voronoi doodles)
Now I will post images always under 280-300 Kb each.
Ciao!
7177.97 In reply to 7177.95
...Done 2 :)
I've changed also my other 2 images of "voronoi glass"
Ciao!
Marco (mkdm)
7177.98 In reply to 7177.97
how did you make smooth edges on your gold box?
7177.99 In reply to 7177.98
Hi glmr.
Well...I first chamfered in Moi the edges of the Voronoi walls, as you can see here
Then I exported in obj format and finally loaded in 3D-Coat.
There I have voxelized the imported object and applied a Shader.
Last stage, the render with 3D-Coat's Render Room using its builtin PBR renderer.
I often use this "trick" to create "quick and dirt" rendering with super smooth edges without the need to do the "fillet" stage in Moi.
Using 3D-Coat's Voxels I can get super-exaggerated smooth edges in the blink of an eye.
But in this case you need to create Voxels with very high poly count, many millions, and you need a decent CPU+GPU to do that.
But if you have time to spent and want to do the things with better precision then I'm pretty sure that you can fillet the Voronoi walls directly in Moi.
Anyway...this is just one of many ways to get "smooth" edges on Voronoi structures.
3D-Coa's way is one of my preferred, but only because it fits perfectly in one of my wokflows for "2D/3D image composition".
Quick and easy.
But it's a very personal technique, maybe others can find it too "coarse".
Ciao!
7177.100 In reply to 7177.99
<< you can fillet the Voronoi walls directly in Moi.
With some prudence!
Because there are some sharpen angles in a voronoi diagram and the input will be the best minimum acceptable of all corners!
As there are a lot of them you have all luck that your calcul fillets failed!
Maybe increase the Scale size of the all objects before make general fillet!
10 seconds for 100 objects fillets top faces : but the most difficult is to find the best accessible angle! (20 seconds :)
(I7 4 years old : not sure that the graphic card is influent to the calcul ?
EDITED: 6 Mar 2018 by PILOU
7177.101 In reply to 7177.99
thanks!
7177.102
Voronoi.v.1.1.2018.03.07
Added X button. Double click this button to reset a diagram.
Added Filter slider. Use it to remove extra small sides of polygons.
http://moi.maxsm.net/item/48
7177.103 In reply to 7177.102
Thank you very much Max!!
Are you running for a prize ? :)
It seems that this Voronoi plugin is a sort of personal challenge for you.
Great job, great job Max!!!
Only a question, if I may...
I did some test but I can't figure out how the new "Filter" affects the output of the Voronoi.
Could you please write something about it ?
Thanks again.
Show messages:  1-3  …  24-43  44-63  64-83  84-103  104-123  124-143  144-163  …  184-198
