Voronoi Script or plugin
 1-16  17-36  37-56  57-76  77-96  97-116  …  197-198
7177.57
Today I rewrote the script. I switched from Ivan Kuckir's algorithm to Voronoi Javascript library written by Raymond Hill (https://github.com/gorhill/Javascript-Voronoi)
Now it works much better.
http://moi.maxsm.net/item/48
7177.58 In reply to 7177.57
NICE!
thanks a lot!
7177.59 In reply to 7177.57
Thanks a lot Max.
I've made a little test.
Finally now when I chose "Polygon" mode all the polygons generated are "single polygon" and not line segments.
Thank you very much!
You are a perfectionist! :)
My Moi French Site My Gallery
7177.61
This is great fun to play around with, thanks alot Max for taking the time!
I was wondering though, is there a way to remove point during while creating the voronoi?
Nick
7177.62
Voronoi.v.0.9.2018.03.01 ;)
I know about an overlapping bug. I'll fix it tomorrow.
7177.63 In reply to 7177.62
will this fix also keep a similar distance between curves?
7177.64 In reply to 7177.63
...you want the "moon" :)
7177.65 In reply to 7177.64
less than one half =)
7177.66 In reply to 7177.63
The usual trick is to have a distance between the edges was that one draws
a control point curve around the corners of each cells and offset then a little
bit inwards.
That's how i have done it in the past with my Voronoi Eggs.
https://www.behance.net/gallery/34247989/Voronoi-Egg-CVT
7177.67 In reply to 7177.63
Hi glmr,
yes.
between polygons
7177.68 In reply to 7177.66
did you make these eggs in Moi3d??? I thought it is possible only with Paneling tools from Rhino
7177.69 In reply to 7177.67
nice! looking forward for your update
7177.70 In reply to 7177.68
i used various tools to create the voronoi structure and finally used MoI to model the eggs, so no paneling
with Rhino etc.
7177.71
7177.72 In reply to 7177.71
7177.73 In reply to 7177.71
Thanks a lot Max !
7177.74
Thanks Max
www.jameselliott.co.uk
Always funny!
7177.76 In reply to 7177.75
how???
Show messages:  1-16  17-36  37-56  57-76  77-96  97-116  117-136  …  197-198
