Voronoi Script or plugin
 1-16  …  77-96  97-116  117-136  137-156  157-176  …  197-198
7177.117 In reply to 7177.116
Hi Brian
you can use ImportPointFile script (http://kyticka.webzdarma.cz/3d/moi/#ImportPointFile)
then select points and run voronoi script
7177.118
Hi Max
Thanks for all
some hope of having Voronoi tool in Nodeeditor ....
alberto
7177.119 In reply to 7177.117
Hi Max.
Wanderul!!!
I wasn't aware of this opportunity!
Good to know. Thanks.
<< select points and run voronoi script
So... :)
7177.121
Alberto
I don't know when. I have a plan to add a couple of new powerful features. It will be more important improvement than adding of voronoi node.
Maybe after that I'll add voronoi node.
Marco
>>The new thread I wanted to create should be : "PUBLIC THANKS TO MAX SMIRNOV FOR ALL HIS AMAZING AND PRICELESS JOB!!!"
Thank you Marco, but I think it is not a good idea :) The current amount of thanks is enough for me, so we don't need to create a separate thread. ;)
For leaves or fish's bones :)
EDITED: 9 Mar 2018 by PILOU
7177.123 In reply to 7177.120
WOW !!!! Super coooool!!!!
Thanks!
7177.124 In reply to 7177.121
Hello Max!
@You : "...Thank you Marco, but I think it is not a good idea :) The current amount of thanks is enough for me, so we don't need to create a separate thread. ;).."
OK Max :)
Thank you very much for all your amazing plugins!!
7177.125
Hi Max
Maybe after that I'll add voronoi node.<<
good sound for me , are your words
what else to say ...
good work and we hope to meet soon
Voronoi Node
have a nice day
alberto
7177.126 In reply to 7177.117
Thank you Max:-)
Message 7177.127 deleted 9 Mar 2018 by GLMR
7177.128 In reply to 7177.126
Hi Max,
i tried your script (old version) under OS X with 5000 points but i don't get the desired result.
For comparison i attach pictures from Adrian Secord's Weighted Voronoi Stippler (2) and MoI (1) script output.
I used his points output for x,y and added with sed z = 0.0000000 coordinates.
Attached is also the points file.
O.k. scaled now with factor 100, much better, but still not there.
Maybe i have to try MoI v4 with your latest version.
7177.130 In reply to 7177.129
Hi Stefan
forget about the first version :)
Latest version uses different algorithm and it works much better.
Also it works fine with both MoI 3.0 and 4.0.
EDITED: 7 Mar 2022 by SMIRNOV
7177.131
Voronoi.v.1.11.2018.03.09
Made some performance improvement (thanks to Stefan)
http://moi.maxsm.net/item/48
WOW Max,
thanks a lot! I will then use your new version immediately! :-)
Best regards
EDITED: 9 Mar 2018 by STEFAN
Message 7177.133 deleted 9 Mar 2018 by GLMR
My Moi French Site My Gallery
Hi Max,
i just tested the new version, amazing!
(Did a quick PayPal donation. :-))
Best regards
7177.136 In reply to 7177.135
Hi Stefan
Thank you! :)
Show messages:  1-16  …  57-76  77-96  97-116  117-136  137-156  157-176  177-196  197-198
