Voronoi Script or plugin
 1-19  …  60-79  80-99  100-119  120-139  140-159  …  180-198
7177.100 In reply to 7177.99
<< you can fillet the Voronoi walls directly in Moi.
With some prudence!
Because there are some sharpen angles in a voronoi diagram and the input will be the best minimum acceptable of all corners!
As there are a lot of them you have all luck that your calcul fillets failed!
Maybe increase the Scale size of the all objects before make general fillet!
10 seconds for 100 objects fillets top faces : but the most difficult is to find the best accessible angle! (20 seconds :)
(I7 4 years old : not sure that the graphic card is influent to the calcul ?
EDITED: 6 Mar 2018 by PILOU
7177.101 In reply to 7177.99
thanks!
7177.102
Voronoi.v.1.1.2018.03.07
Added X button. Double click this button to reset a diagram.
Added Filter slider. Use it to remove extra small sides of polygons.
http://moi.maxsm.net/item/48
7177.103 In reply to 7177.102
Thank you very much Max!!
Are you running for a prize ? :)
It seems that this Voronoi plugin is a sort of personal challenge for you.
Great job, great job Max!!!
Only a question, if I may...
I did some test but I can't figure out how the new "Filter" affects the output of the Voronoi.
Could you please write something about it ?
Thanks again.
7177.104 In reply to 7177.102
My Moi French Site My Gallery
7177.105 In reply to 7177.103
Hi Marco
No, it's not a challenge. I just want to make a good script and then forget about it.
It doesn't affects the output if Corners slider set to 0. Set corners to 100 and the move the Filter slider.
7177.106 In reply to 7177.105
Ciao Max!
@You : "...It doesn't affects the output if Corners slider set to 0. Set corners to 100 and the move the Filter slider..."
Perfect! Got it.
Tested and now is...perfect!!
@You : "...I just want to make a good script and then forget about it..."
OK! Then you can sleep soundly :) You created an AMAZING script.
Thanks a lot for all your effort.
Ciao!
7177.107 In reply to 7177.105
Max...your wanderful script gave me an inspiration..."How to brake in two each Voronoi cell and make a funny thing"
Look at this video : http://take.ms/pBFZS
In short the process I have used is :
1 Select all Voronoi curves
2 Apply the "mark curve start" plugin
3 Select again all Voronoi curves
4 Apply the "mark curve middle point" plugin
5 Trim the Voronoi curves with the generated points of steps 2 and 4
6 Close all the "half curves" with the command "closecurve"
You can download all the plugins I've used at : http://take.ms/uAgYy
Unzip and copy the files into the Moi's "commands" folder.
THOSE CUSTOM COMMANDS WHERE TESTED WITH MOI V3
I suppose they should work also with Moi V4 but I didn't try)
Ciao!
7177.108 In reply to 7177.107
P.S....forgot to say that I've used also another Max's custom command : "PatternSelection"
You can grab it here : http://take.ms/0F9I8
Ciao!
7177.109 In reply to 7177.105
I was waiting for this moment sooo long. Now your script is perfect, just perfect! Thank you very much!
Hello everyone!
I admit I was tempted to create on the fly a brand new thread but I want to submit this thought to all "colleagues" moiers :)
The new thread I wanted to create should be : "PUBLIC THANKS TO MAX SMIRNOV FOR ALL HIS AMAZING AND PRICELESS JOB!!!"
I think it should deserve much more than this but anyway...tell me what do you think ?
Best thanks is use the Max's scripts! ;)
7177.112 In reply to 7177.111
Yes Pilou!
You're right...but I think that maybe a public thank could b a nice thing for him....I don't know :)
7177.113
Thanks Max!
EDITED: 18 Oct 2018 by SBEECH
With the little trick above :) http://moi3d.com/forum/index.php?webtag=MOI&msg=7177.81
(2 different grids Isected then ExplodeMoved: one with Corners =0, other Corners = 100 )
PS Subdiv (not applied here) don't works with all volumes ( surely some > 5 polygons! )
EDITED: 8 Mar 2018 by PILOU
7177.115 In reply to 7177.114
Very nice!
A sort of "fragments of an exploded planets" :)
Is it possible to add a file of points, as input to the voronoi script?
7177.117 In reply to 7177.116
Hi Brian
you can use ImportPointFile script (http://kyticka.webzdarma.cz/3d/moi/#ImportPointFile)
then select points and run voronoi script
7177.118
Hi Max
Thanks for all
some hope of having Voronoi tool in Nodeeditor ....
alberto
7177.119 In reply to 7177.117
Hi Max.
Wanderul!!!
I wasn't aware of this opportunity!
Good to know. Thanks.
Show messages:  1-19  …  40-59  60-79  80-99  100-119  120-139  140-159  160-179  180-198
