AMONIT modelling
 1-3  4-23  24-36
7172.24 In reply to 7172.22
Hi Lara, are you trying to run the BoundingBoxCenter command?
If so from that error message it looks like you probably need to adjust your shortcut key - it looks like you have the command part for your shortcut key to be "bounding box center" with some spaces in there. Try taking out those spaces, the command name is "BoundingBoxCenter" with no spaces in it.
7172.25
Thank you.
I tried it with BoundingBoxCenter (before: bounding box center).
No error this time - fine. But also not an operation - ces´t dommage.
My workflow like seen in Pilous video:
1. Making the base ellipse
2. Creating a Center Point (a second object - a tiny circle)
3. Named both as "Base"
4. Made the array along the helix
5. Hided the helix
6. Activated all objects
7. Did with B (my shortcut) the BoundingBoxCenter
...no operation followed
Where is my mistake?
7172.26
Hello,
Basic spiral using sweep in sections. Are you trying to construct a sink mold? If so you would need to reverse the wall height to be able to cut it away from the sink base and do some filleting and figure out the plumbing. You could still use Sweep to make ridges in the model. I'm not sure if there is a script to automatically draw perpendicular lines between two curves but that would save you a bunch of construction time.
<< 7. Did with B (my shortcut) the BoundingBoxCenter
Presume all objects + "the" point of each object are selected
You must press Tab then write ScaleArray : nothing to do with BoundingBoxCenter ;)
(except for the first point if you want like the little video following,
but this first point can be anywhere! So you can just click this first point without BoundingBoxCenter!
EDITED: 15 Jan 2015 by PILOU
7172.28 In reply to 7172.25
Hi Lara,
It may be a little bit difficult to see the result - the command BoundingBoxCenter puts a point object at the center of the bounding box around the selected objects. So after you run it, a point object should appear, it will be a small marker at the center of the selected objects.
It sounds like you may be expecting something else to happen instead?
7172.29
Hello,
now I´ve got the basic operations.
THANK YOU VERY VERY MUCH for your patience and helpfulness and your spent time.
So beautyful to know that you are not alone in this world and people help together.
My last question for the moment is, how do I arrange it that the swept objects along the helix do point into the center of the helix?
Best regards, Lara
EDITED: 10 Feb 2021 by MALA
7172.30 In reply to 7172.29
Maybe something like this ;)
7172.31 In reply to 7172.29
Hi Lara,
I'm not entirely sure I understand what the "swept objects along the helix" means - do you mean you want to reposition the profile curves used for the sweep so they are all on lines radiating out from the center point?
If so then maybe setting up a guide line like Pilou shows above and then using those lines as snapping guides to reposition the profiles.
Probably the easiest way to reposition a curve to a different orientation in the Top view is to use the Transform > Orient > Line to Line command.
To use orient line to line, select the object you want to reposition, then run the Transform > Orient > Line to line command, it will then ask you to select a base start point and a base end point. in the Top view snap these onto the curve you are repositioning. Then it will ask you for a target start and end point, you want to select the target start point onto the helix, and then select the target end point onto the guide line, or instead of using guide lines you can use the "perpendicular" straight snap for the second target point to make the second point come off perpendicular from the helix.
7172.32
Hello,
I'm sorry I wasn't clear on the Sweep construction. The green lines were setup to be perpendicular to the curves, and the orange three point arc was Scaled and Aligned to the green lines seen here. Once the initial outer section was Swept, subsequent sections spiraling inward were Swept using the edge of the surface and the following curve. If you wanted to make the sink you would increase the size of the inner orange curves and decrease the size of the outside. If it's helpful I think I have some time to make a short video of the process. Keep in mind it's just one of a few different ways you can construct this model, you may come up with a more efficient way to do so.
7172.33 In reply to 7172.32
Hello OSTexo,
my english is not so good - and I guess this is why I do not understand what your intention in this ammonite thread is?!
Do you want to make an ammonit for yourselves? Or are these suggestions in order to show me an alternative modeling concept?
7172.34
Hello Michael and Pilou,
now I think the steps for going into the final ammonit modeling are clear to me!
Thanks a lot.
Lara
7172.35
Hello,
Correct, an alternative modeling method.
Another method ;)
Log Spiral by Bemfarmer
http://moi3d.com/forum/index.php?webtag=MOI&msg=4543.1
+ Rail Revolve
Show messages:  1-3  4-23  24-36
