Backing up the computer
All  1-3  4-9
7169.4
Hi Brian, sorry about the failed drive. I know how horrible it is.
You can try http://www.r-studio.com
They have a free version that will list the content of your drive, if its salvageable, and then pay for the full version.
It's not that expensive anyway, and i've had great results from it.
Hope it works out.
Dinos
7169.5 In reply to 7169.1
Hey brian,
If you lost your moi script work i can get you those back, although i only kept final iterations and may have changed your naming conventions slightly...
Also, with an ssd, you will most definitely want to have a good backup plan and software.
Frenchys country has a good saying for this situation...
7169.6 In reply to 7169.1
What a bummer.
I'm also rather lax about backing up. To offset this I use 2 hard drives in RAID 1 configuration in which data is written to 2 drives simultaneously.
This is good protection against hard drive failure as it is very unlikely for both to fail at the same time.
Of course it doesn't protect against a nasty virus - nor against lightening strikes!
Here's a wiki link should you wish to read more: http://en.wikipedia.org/wiki/RAID
Mike.
Thanks to everyone.
The script situation is good, having about 16 USB sticks. The latest SanDisk USB stick is 64 GB, USB 3.0!
It helps to have some on work computer and laptop.
I'll likely try R-Studio.
I've succeeded in recovering most of my hard drive data. A "few" files were damaged, or their locations "scrambled."
Moi ini file recovered, photos, music, most scripts, etc. The data will be copied to new hard drive, with Windows7 and all programs newly installed.
In case anyone becomes interested in recovering data, here are a few notes, for the situation where the bad drive is no longer recognized by Windows7, but is recognized by the low level bios.
Rule 1, for very valuable data, is to stop using the drive and send it, and lots of $, to professionals. This option was not used.
The longer the drive is used, the worse the drive may become.
Personal recovery attempts require some computer experience and knowledge, and there is a DANGER that using the incorrect hard drive names may result in a good hard drive being overwritten with other data!
Although Ubuntu could have been used, it was not.
It was very convenient to purchase, for $9.95, the Parted Magic tools, as an iso file, and burn it to a DVD. http://partedmagic.com/
This is a version of Linux, and contains recent copies of the needed software. The computers bios setting is simply adjusted to boot from the DVD.
This brings up a Graphical User Interface, (GUI), where the two programs, DDRescue and TestDisk may be run from a Terminal Command Line, kind of like the old dos programs. DDRescue is NOT the same program as the old program DD and is not the same as DD_Rescue.
Guide #1: https://www.technibble.com/guide-using-ddrescue-recover-data/ This is an excellent guide. Part 1 explains the names of the hard drives.
It is very important to properly identify the hard drives, in order to copy From the bad drive, to a new drive, or an image file.
Every time the computer is rebooted to the DVD, the names CHANGED. I think sd stands for system device.
The names of the hard drives, (or a solid state drive, or a USB hard drive, or USB thumbdrive), are /dev/sda, /dev/sdb, /dev/sdc, dev/sdd, etcetera.
If present, /dev/sda1 stands for partition one of /dev/sda, and sda2 stands for partition two, etc.
Guide #2: http://html5.litten.com/windows-file-recovery-series-part-4-recover-files-from-a-bad-hard-drive/ is another excellent guide.
Well, I wrote up some more rough notes of the trials and tribulations encountered, but the Guides cover the procedures, so I elected not to post them, as
there are so many little details to cover. Also read the reason for putting a hard drive in a freezer, on the web. It is to shrink bearings,
to improve rotation, (of motor+), if the "lubricant" is bad. This was not done.
7169.9 In reply to 7169.8
That's great news Brian that you were able to recover most of your data!
Show messages: All  1-3  4-9
