Javascript Diagnostic Output?
All  1-3  4-8
7161.4 In reply to 7161.3
The "alert" popups eventually showed me that I'd had an error in my regular expression, so I'd solved my initial problem. But using the log will be much better as I continue to do other work!
I read somewhere in these forums where you mentioned that there might one day be an ini file setting to bypass caching of Javascript files. I know that the scripting API is (and probably should be) a relatively low priority, but I would vote for that feature if it were not too difficult to implement.
Thank you,
___Samuel___
7161.5 In reply to 7161.4
Hi Samuel, I'm glad you've got the initial problem solved!
re: file caching - that did get implemented in Moi v3, go to Options > General and push the "Edit .ini file" button, and inside there set DisableFileCaching=y . That will make MoI freshly reload the file every time a command is run rather than caching them in memory like it will do by default. More info here:
http://moi3d.com/forum/index.php?webtag=MOI&msg=6727.2
7161.6 In reply to 7161.5
You seem to anticipate every feature I think I want :)
Thanks!
___Samuel___
7161.7
I use moi.log and modified ShowLog.htm with autoupdate and autoscroll.
And a text labels placed in the scene.
P.S. Michael, is there any possibility to clear the log?
EDITED: 7 Mar 2022 by SMIRNOV
7161.8 In reply to 7161.7
Hi Max, sorry no there's not currently any way to clear the log.
I can add something for that for v4, and also probably can add something to make the log get dynamically shown a system debug output viewer.
Show messages: All  1-3  4-8
