Hi Bartosh, yes the link from Marco above shows where to go to adjust lighting settings and gives several different setting combinations for different effects.
Once you have set it up, you can export that shaded image to either PDF or AI formats. The generated file will be a hybrid of part vector, part bitmap. Edges and silhouettes will be vector curves in the 2D file and the shaded surfaces will be a background bitmap behind them.
