Rendering MoI Models
 1-14  15-34  35-45
7145.15
Hello,
Thearender
7145.16
Marmoset Toolbag 2
7145.17
Octane
7145.18 In reply to 7145.16
Toolbag2 looks great
it would be great to have a MOI AppLink or something else.
7145.19
Strata Design 3D CX 7.5
7145.20
Modo !
- The preview renderer is very fast, interactive, and can be used as 'final renderer' with really few quality settings to tweak
- Tons of features (cpu)
- Thanks to the photoview 360 heritage (solidwork version of modo render rengine), modo can render sexy wireframe from nurbs surfaces.
EDITED: 3 Dec 2015 by PAQ
Sexy Technology! :)
7145.22 In reply to 7145.20
That's pretty cool. Wish Keyshot could do that!
7145.23 In reply to 7145.20
I'm following Modo ... soon or later i'll jump into it
Paq>photoview 360 heritage (solidwork version of modo render rengine
What you mean:is a plug-in?
7145.24 In reply to 7145.23
Hi Mauro,
They call it an 'add-in', my is guess is that it comes 'embedded' with solidworks.
http://www.solidworks.com/sw/products/3d-cad/photoview-360.htm
Hi Mauro,
You may hurry up then a bit… The Carlyle Group is selling The Foundry next year… and no one knows yet what will happen then to MODO.
7145.26
Hello,
The vector output on MoI is excellent in my opinion and can be used along with drawing applications to produce full vector drawings including backgrounds. Here is a raster grab of a few of the full vector images.
7145.27
Hi guyver (DAVGIAN)
re: Toolbag2 looks great, it would be great to have a MOI AppLink or something else.
Marmoset Toolbag2 makes excellent renders, it's fast (like instantaneous, though I've not tried it on large models), relatively cheap, and easy to use. You can render out in lots of different sizes. The turntable animation display feature is great, with object, sky and camera automated rotation at different speeds, plus it can generate a series of captures, so you can create a video. There are 25 materials included and you can make your own using Photoshop, Substance Painter, etc.
It's really easy to move a model from Moi to Toolbag2, just same your model once as a regular Moi file, save out as an OBJ file, and import the mesh into Toolbag2. You can then make changes in Moi, delete the item in the Toolbag2 scene tree and re-import the mesh. To make this process faster I save the OBJ file from Moi in a single keystroke with no dialog box, see below. Also when importing a mesh, if you keep the import mesh dialog box sorted by date, your Moi model will always be the first item in the file list. It takes like 3-5 seconds to do.
A couple of downsides to Marmoset. It does not support a 3D mouse. On large monitors the UI is tiny.
Note that if you want different materials on separate parts of your model don't union/join them together in Moi, and give them a different name in the Object list, or don't name them at all. Applying a material to a model is just drag and drop.
Michael put together a keyboard shortcut script to save out an OBJ file in a single key stroke with no user dialog (make sure to save your model once because it needs a current file name to work):
script: /* SaveAs OBJ no dialog */ var name = moi.geometryDatabase.currentFileName; if ( name != '' ) { moi.geometryDatabase.saveAs( name.substr(0, name.length-3) + 'obj', 'NoUI=true' ); }
Look at this discussion for setting the various SaveAs parameters: "File Scripts" 7119.1
I've used the following settings with great results and assign it to a function key:
function DoSaveAsObj() {
if ( name != '' ) {
'NoUI=true;Output=quads;Display=shadedwithedges;Weld=false;Angle=3;MaxLength=3;MaxLengthApplyTo=curved' );
DoSaveAsObj();
Here is that function as a single line script:
script: /* SaveAsObj no dialog */ var name = moi.geometryDatabase.currentFileName; if ( name != '' ) { moi.geometryDatabase.saveAs( name.substr(0, name.length-3) + 'obj', 'NoUI=true;Output=quads;Display=shadedwithedges;Weld=false;Angle=3;MaxLength=3;MaxLengthApplyTo=curved' ); }
HTH
EDITED: 30 Dec 2014 by ROBERTH
Size: 224.5 KB, Downloaded: 147 times, Dimensions: 684x716px
Size: 126 KB, Downloaded: 36 times, Dimensions: 816x1025px
7145.28
Thank you Pascal & Stefan
Happy New Year
7145.29
Just got an email from Marmoset:
Now through New Year's Day all Marmoset software is 30% OFF
7145.30
native modo, vray for modo, or octane for modo.
each has their own strengths. For quick and dirty renders, I use octane. For anything with more complicated materials, I use vray or modo
7145.31
Just emailed Marmoset asking if they still had a sale going on (doesn't hurt to ask right?). It's 10:15 California time and they answered right away! Now that's great service. I missed the sale but will give the try-out a go for sure!
-Alan
7145.32 In reply to 7145.27
Robert: I'm trying the demo of Toolbag2. How you handle not having a UV map from Moi? I'm finding that you need a UV map in order to apply textures.
THanks,
Alan
7145.33
Maxwellrender
7145.34
@ OSTexo: how / with what did you generate these raster shadings?
tnx
wim
Show messages:  1-14  15-34  35-45
