custom IU
All  1  2-5
7144.2 In reply to 7144.1
Hi Mike, there's definitely something wrong with the install there, did you possibly do something like entirely replace the existing UI folder with the one in the custom UI?
I guess it looks like you've somehow managed to delete the \icons sub-folder or something like that.
To install the custom UI, you need to unzip it and copy the files over into the regular MoI UI folder, and just one file named CommandBar.htm will get overwritten. You don't want to delete the existing stuff like it seems you've ended up doing somehow.
7144.3 In reply to 7144.1
I guess take a look at the \ui\icons sub-folder. That's probably what is missing to get a result looking like what you show there... Because it appears you've got other things like the side pane still there, but nothing from the icons sub-folder.
If you need to re-install it, you can get a new download of the installer at http://moi3d.com/reinstall.htm
7144.4 In reply to 7144.3
I have it working thanks to your direction. Is there a master list of scripts and how to install them any where?
Thanks!
7144.5 In reply to 7144.4
Hi Mike, the closest thing to a master list of scripts is Petr's page which has a bunch of them collected. Go to http://moi3d.com and then the Resources page, and the link to it is in the top section there.
Show messages: All  1  2-5
