How to calculate m² of an area?
All  1  2-5
7116.2 In reply to 7116.1
Export in skp format or 3ds and use free Sketchup function! ;)
http://www.sketchup.com/products/sketchup-make
7116.3 In reply to 7116.1
There is a script for the area of the face of Planar polygons called "polygon face area."
It does not do edges, it needs a planar face. It does not work with curves.
7116.4 In reply to 7116.1
Hi B-W-Design,
re: Is it possible to calculate the m² of an plane area?
Sorry, currently there is not anything set up in MoI by default to give area or volume measurements. That is something that I plan to work on adding in the future though.
For the time being you would need to export your plane to a different CAD program and measure the area there.
You can also try the script Brian mentions above, that's available here:
http://moi3d.com/forum/index.php?webtag=MOI&msg=5549.12
7116.5
Hi Guys,
sorry for late answering.
The export-method i used all the time. and it sucks. It works. but it sucks.
The script Brian mentions is pretty cool. It has many limmits, but i think i know how i coudl use it to get what i want.
if it works right, it is very accurat.
Would be very very very cool if you, Michael, could implement something in the future.
Thanks all of you.
Show messages: All  1  2-5
