Feedback with V3, Mac OS 10.6
All  1-3  4-6
7107.4 In reply to 7107.3
Hi Leonard,
> Would it be possible for Moi's behavior to be altered by a flagging graphics card?
Well it's possible but probably not too likely. Problems with the graphics card usually make display related problems or more severe problems like crashes, not typically kind of subtle problems in program behavior. It's more likely to be some kind of bug with Wine, maybe only on OSX 10.6, it's hard to know for sure without more feedback from others.
7107.5
FWIW, I've been using MoI for hours at a time on Mac OS 10.10 and have not seen problems as defined in #1. In fact I've left it open over the weekend and resumed on a Monday and I've been rather surprised on the overall robustness of the app as compared to other 3D apps I'm used to (Lightwave Modeler and SketchUp to name two). I might suggest the OP to update their Mac. I believe the updates are free.
7107.6 In reply to 7107.4
The issue is in progress.
After working in Moi for about an hour, I moved over to Cinema4D leaving 1 Moi file active and 2 open in the background. I returned to Moi after about an hour in C4D and the work area appeared fine but the right margin tools and the Objects/Types/Styles menus and the screen bottom control areas were solid black (pic attached). After a few moments, and starting with the appearance of one label from the Object menu, the active window recovered gradually and then quickly. I opened a new window to import a pdf of a scaled figure. The import was normal. When I tried to flip the figure the entire field - active curve and Moi background - moved in unison. Strangely, the other 3 windows, when each was brought to the front, behaved normally. I returned to the problem file and it was still not right. I left the Moi file with a test file open to write this email. I just went back to the Moi file, prepared to video what is happening and when I clicked on the test file circle tool, the window suddenly jumped to the problem file. More strangeness: the problem file resumed working normally.
L.
Size: 68.1 KB, Downloaded: 193 times, Dimensions: 1000x563px
Show messages: All  1-3  4-6
