Thickness of lines
All  1  2-3
7091.2 In reply to 7091.1
Hi Jay - when MoI is active press the Tab key to put focus into the xyz input control on the bottom toolbar, and type the following and push enter:
script:moi.view.lineWidth = 1
That should reset your line width back down to the default again.
The line width getting messed up is a side effect of that high resolution screen capture failing and preventing the cleanup part of the script from running.
7091.3
Thank You!!! That helps!
Show messages: All  1  2-3
