Generating Outlines and Silhouettes With Make2D?
All  1  2-5
7090.2 In reply to 7090.1
Hi OSTexo, sorry no there isn't any mechanism set up currently in Make2D to generate outlines or silhouettes, it only has visible and hidden lines set up.
The issue with outlines and silhouettes is that they usually overlap right on top of other curves and since MoI does not currently have separate line widths inside of it, it would be difficult to judge what they looked like inside of MoI.
Probably in the future when MoI supports line widths in styles it would then work better to have Make2D be able to generate outlines and silhouettes.
7090.3
Hello Michael,
That makes sense, my current workflow consists of doing a PDF export out of MoI with outlines and silhouettes, opening the file and peeling those layers into separate files and doing a reimport of those files into MoI for finishing work. I assign the layers separate colors in MoI to keep things understandable, export out, and reassign line weights in the vector application based upon the colors I've assigned in MoI. I'm sorry for not being too clear in my initial question.
7090.4
Sounds interesting. I just read the MoI reference's description of the Make2D command, but I don't understand how you would use it. Could you please explain it a little?
Thanks!
— Metin
metinseven.com — 3D (print) design • animation • artwork • illustration • visualization
7090.5 In reply to 7090.4
Hi Metin, Make2D generates a hidden line 2D drawing similar to how PDF, AI, and DXF 2D exports work, with the main difference being that Make2D keeps the generated 2D curves right in MoI rather than outputting them to a file.
You can use it if you expect to do further work on the 2D curves inside of MoI.
Show messages: All  1  2-5
