How to merge coplanar surfaces?
7058.1
Here I've raised the walls of this solid box using the Extrude command. Now I have two sections: 1 and 2. How can a merge these so that the wall shows only 1 section? I've tried <tab> merge in the command line, but it doesn't seem to do the trick.
Thanks for any help. :)
7058.2 In reply to 7058.1
If walls are solid use Bolean- Uniun, if joined surfaces use - Join.
My Portfolio: www.samardac.com
A lot of my Tutorials!
7058.3
I don't think that will work. Consider this model:
https://altuit.cloud/web/dbpub/3D/SolidProblem.3dm
Here's a picture of the issues:
1. How to get rid of the dividing line and merge the two rows into one?
2. How to get rid of this rectangle which is part of the solid?
3. Why is the render of this area funny? Is it an OpenGL error?
7058.4 In reply to 7058.3
Hi Chipp, Boolean Union will merge 2 coplanar adjacent planes into one single big plane so that's one method.
It will only work on planar surfaces though, not the rounded extruded ones in the corner area of your #2.
Sometimes it is easiest to just delete things and rebuild bigger surfaces, like for your rounded corners, delete the 2 stacked faces and then select the bottom edge and extrude it upwards and then join the extrusion in. Sometimes it's easiest to do the same thing with planar surfaces too, just delete the pieces so you have a big planar opening and use Construct > Planar to fill it in. You can run Construct > Planar in 2 different modes, either giving it a curves selection which will build trimmed plane to those curves, or giving it a joined surface and it will find naked edges in it that form closed planar boundaries and seal those off automatically joining them in too.
But another way is if you use Edit > Separate on the planes to get them to be individual surfaces, then select those and run boolean union that will then run through the coplanar merging process that is part of the booleans.
The #3 is indeed just a visual display glitch, it has to do with a pulling forward in depth to avoid curves becoming stippled and occluded by the surfaces they are sitting on. As a side effect of that pulling forward you can get bleed through instead of stippling, especially in thin wall areas. I will probably be trying some things to reduce that in the future but for now it's just a type of display artifact that you should ignore.
Direct method: just erase all except the top perimeter :)
Extrude
Boolean Diff one Box
Boolean Diff an half Cylinder
all takes 15 seconds
et voila! :)
