Twisty Donut Ring Help?
All  1-3  4-6
7047.4 In reply to 7047.3
Hi Snake, yes the deform tools are new for version 3.
You can get a v3 upgrade from here:
http://www.studica.com/moi3d
The one you would need is the "Academic Upgrade from V2.0" .
You could also get the v3 trial version from here if you just want to test those new features:
http://moi3d.com/download.htm
7047.5 In reply to 7047.4
Wow! Thanks! That was super helpful! I got version 3 and it's working great! One quick question though. Is there some mathematical formula that tells me what degree I should rotate the object before flowing it so that the ends can line up, or is it just guess and check?
7047.6 In reply to 7047.5
Hi Snake,
Well it will be different depending on what shape you are twisting.
If you have a square base shape then you would want the twist to be a multiple of 90 degrees, like any of 90, 180, 270, 360, etc...
With different base shapes that would also be different too though.
Show messages: All  1-3  4-6
