Hi Metin, the Mac version does not normally need anything installed separately, all the stuff it needs is packaged along with it already so you just unzip the app, and put it wherever you want and run it from there. The first time you run it you need to right-click it and choose "open" on the menu that pops up since it is not digitally signed. Then after the first time you just double click on the app to run it.
> Has there maybe been a minor bug-fix update since then, so I should download the
> latest version before installing on Max OS X?
No, the one you downloaded already is the current version, you don't need to download it again.
Make sure though that you did not unzip it on the PC, you need to unzip it on a Mac only so the file permissions all stay intact. If you already unzipped it on your PC previously then do download a new one.
