Is there a way to sync shortcuts or expor/import them easily?
All
1-5
6-8
Michael Gibson
18 Nov 2014 (6 of 8)
7043.6
In reply to
7043.4
Hi Chipp,
> FWIW, it would be nice to be able to *assign* the path for the moi.ini file.
You can make that happen if you give moi.exe a command line parameter that has the full path to the moi.ini file that you want to use.
On the Mac the place to set the parameter is kind of hidden, see this previous post for a description for how to set it:
http://moi3d.com/forum/index.php?webtag=MOI&msg=4675.8
Reply
More
Reply as PM
Print
Mark as unread
Relationship
IP
Logged
TpwUK
19 Nov 2014 (7 of 8)
7043.7
In reply to
7043.3
Hi chipp, the double boot after a crash is normally related to a corrupted cache so it needs two reboots to rebuild it. One to detect the faulty cache, and then on the next boot OS x knows to flush and rebuild it.
Martin Spencer-Ford
Reply
More
Reply as PM
Print
Mark as unread
Relationship
IP
Logged
chippwalters
20 Nov 2014 (8 of 8)
7043.8
In reply to
7043.6
Thanks for the tip. It's a bit more complicated so I created a video to show exactly how to 'redirect' MoI to a new moi.ini file location:
http://youtu.be/ijQwMRQJLj8
Reply
More
Reply as PM
Print
Mark as unread
Relationship
IP
Logged
Reply to All
All
1-5
6-8
