Is there a way to sync shortcuts or expor/import them easily?
All  1-2  3-8
7043.3 In reply to 7043.2
Thanks Michael,
For some reason, it didn't like it when I did it the first time. I suspect it may had something to do with licensing. Funny thing is, MoI crashed my Mac hard and it took 2 reboots to get back up-- so I figured I ought not to *replace* the whole file. I'll try again. Much appreciated!
7043.4 In reply to 7043.3
FWIW, it would be nice to be able to *assign* the path for the moi.ini file. That way I could put it in my Dropbox folder and it when it updated, it would be used by both my machines.
7043.5 In reply to 7043.3
Hi Chipp,
Hmmm, well the license key is not supposed to have anything to do with moi.ini - it's stored in a separate file alongside moi.ini ...
Well a crash like that is definitely odd but I doubt it has much to do with copying over top of moi.ini . Let me know if you continue to run into things like that.
7043.6 In reply to 7043.4
Hi Chipp,
You can make that happen if you give moi.exe a command line parameter that has the full path to the moi.ini file that you want to use.
On the Mac the place to set the parameter is kind of hidden, see this previous post for a description for how to set it:
http://moi3d.com/forum/index.php?webtag=MOI&msg=4675.8
7043.7 In reply to 7043.3
Hi chipp, the double boot after a crash is normally related to a corrupted cache so it needs two reboots to rebuild it. One to detect the faulty cache, and then on the next boot OS x knows to flush and rebuild it.
Martin Spencer-Ford
7043.8 In reply to 7043.6
Thanks for the tip. It's a bit more complicated so I created a video to show exactly how to 'redirect' MoI to a new moi.ini file location:
http://youtu.be/ijQwMRQJLj8
Show messages: All  1-2  3-8
