Distributed Spacing
All  1-2  3-7
7041.3 In reply to 7041.2
yes it should be evenly distributed by the bounding box center. Sorry my english isn't that good so please take a look at the examples.
From front view:
From top view:
This feature is from illustrator and I can image this being a part of the align tools in the future:
Thank you
7041.4 In reply to 7041.3
Hi Manuel, the part that has always seemed kind of strange to me about that type of arrangement just based on bounding box center is that it's very easy for the objects to collide into one another.
For example, here I did a test with Illustrator with this set of objects doing a horizontal distribute:
The result does not really seem to have much "even-ness" about it - the objects have different amounts of space between their outer boundaries and some of them even overlap over each other.
It's a kind of imprecise arrangement mechanism and that makes it a bit of an odd fit in a CAD program which tends to have more of a focus on accuracy and precision tools.
MoveSlicetoPoint can help you! ;)
http://moi3d.com/forum/messages.php?webtag=MOI&msg=2749.36
Objects can be anything! Curves surfaces, volumes...
EDITED: 19 Nov 2014 by PILOU
7041.6
@ Michael
First of all thanks for your time and reply!
And yes that's true in this case.
But maybe sometimes intersection of the objects is desired (for boolean). This feature would also be handy in some other situations.
For example adjusting points in a curve. I know this could be done manually, but a simple click is faster ;)
@ PILOU
thank you very much. I'll give it a try. But i'd like a one click solution ;)
You have also the plugins of Max Smirnov for some dispersions!
http://moi3d.com/forum/index.php?webtag=MOI&msg=6486.1
Show messages: All  1-2  3-7
