blend & planar sections
All  1-3  4-12
7036.4 In reply to 7036.3
Hi Lordfox, check out here for some description of planar sections blend:
http://moi3d.com/forum/index.php?webtag=MOI&msg=6790.35
If you are still stuck with using it on your particular case, could you please post your 3DM model file so I can take a look at what you're trying to do?
7036.5 In reply to 7036.4
Hello dear Michael, this is what I mean, I didn't see good results and I didn't see sections after using a parallel planar section between two planar sections ..
7036.6 In reply to 7036.5
Hi Lordfox, if you still need more information can you please post the 3DM model file where you didn't get good results so I can look at what you're trying to do there?
The "planar sections" option does not mean to use it between planar sections as the input edges, it means to make the blend create all planar curves for the cross sections that are used to calculate the Blend. Blend constructs a surface basically by lofting through a whole bunch of automatically constructed profile curves that attach between the 2 surfaces. When these profile curves wiggle around it can tend to make lumpy results in the blend. The "Planar sections" option tries to instead make each profile curve go on a single plane and that tends to make them wiggle less and can help avoid them from pushing through each other.
Usually it's used when connecting a closed tubular type surface like a wing shape onto a main body as shown in that previous example:
That's normal that you won't see separate sections displayed - you will only see the Blend surface displayed. The planar sections option just modifies how the blend surface is constructed.
7036.7
Hey, I'm sorry, maybe you can see, what I did made wrong. I did have made a small screencapture-video - it's just a question - HOW TO USE the PLANAR SECTION
http://www.mediafire.com/download/e6w3m98ex4y0k48/test-planar-sections.3dm
http://www.mediafire.com/watch/5q4xp8qs3016eic/Blend-Planar-Sections.avi
7036.8 In reply to 7036.7
Hi Lordfox, Blend in general, whether planar sections or not is just not going to work very well on a case like you have there because you've got such differently shaped things you are trying to blend between.
Planar sections will especially have problems if one of the curves does "back tracking" and does not form a convex shape, and also if the surfaces being blended between have surface normals pointing nearly opposite from one another.
I've attached here an example for where planar sections will help, choose the "up" direction for the planar sections to be along the tubular surface's direction, which is the world z axis direction.
But basically in order to get a good result your objects can't just be wildly dissimilar like your case is, they need to be somewhat more reasonably similarly structured.
7036.9
Okay, thank you :) now I did understand it, so my shapes to different .. okay, I did think, that planar sections will create some morphs/blending between 2 very different shapes, similar like blending in illustrator. ;)
Did you have also a example for the SYNC POINT option?
Thank you so much ;)
I will try also the multiiso script and the lineweb script
7036.10 In reply to 7036.9
Hi Lordfox,
The sync points option allows you to control which spots of the edges will be connected together in the blend surface. By default the edges are matched by distance traveled along each edge, but sometimes it can be better to manually control how things match up.
Here's an example, since the bump in these surfaces are at different lengths along the edge, the default blend surface will sort of have 2 bumps in it like this:
That happens because the default connection between things is to just connect the same percentage distance traveled along each edge, which means the tip of one bump is connected to this spot on the other edge in this case:
You can manually control the connection by adding in sync points, for example adding in sync points in these 2 spots will make this result:
It basically allows you to manually control which areas of the edges will be synchronized with each other during the blend surface generation.
7036.11 In reply to 7036.10
Thanks Michael...a good example :)
7036.12
yes, thank from me too, nice :)
Show messages: All  1-3  4-12
