Need help to blend a organic shape.
All  1-2  3-4
7024.3
Hi Tarek :)
As Michael says you must avoid sharp corners!
Let's try to mantain your shape following Michael's guidelines:
Delete mirrored surface,on top wiev hide loft sections and select contour edges of your shape joining them
Now show points of joined contour and move them where you have sharp corners
select the surface and scale just little bit larger
extrude now contour curve in both directions,so you have a blue-object that trim your surface
now you can mirror just trimmed surface and blend G2,than you can join all surfaces obtaining a solid
file attached below
M
7024.4
Hi Micheal and Mauro,
I am absoluely amazed of the excellent support you are giving new people like myself. Your feedback helped me a lot and alos corrected my way of thinking when moddeling going forward.
Thank you both very much!
Tarek
Show messages: All  1-2  3-4
