screen cap check
All  1-4  5-8
7014.5 In reply to 7014.4
Hi Burr yeah your script is working here, but it generates a square image, probably your viewport is not square and that's the mismatch.
The other kind of screenshot above should probably work better for you since it will snapshot your actual screen rather than generating a brand new image.
7014.6 In reply to 7014.3
Hi michael,
I see. In the past, i thought those were working under the hood and generating custom resolutions, not tied to my monitor. Limited only by my card... i had a few different ones, like up in the 4000 range... i guess i never realized in my tests that it was truncating the result?
7014.7 In reply to 7014.6
Hi Burr,
Well yeah that's actually exactly what it is doing - but when you use a custom resolution that is totally separate from your current monitor display it's basically as if you have resized the MoI window temporarily to that particular custom size, so it can easily be a different size image than the current on screen image width and height.
Does that make sense?
7014.8 In reply to 7014.7
Yes, thanks. I misunderstood what it was doing originally. I can reset the scripts accordingly....
Show messages: All  1-4  5-8
