Selection grow and shrink script?
All  1  2-9
6988.2 In reply to 6988.1
Hi Metin, it's not really feasible for control points because there is not currently any interface available for scripts to access the control point selection. But I think it may be possible to do something for faces and edges, I will take a look at that a while later on today.
6988.3 In reply to 6988.2
Cool, thanks a lot Michael!
— Metin
metinseven.com — 3D (print) design • animation • artwork • illustration • visualization
6988.4 In reply to 6988.1
Hi Metin,
this is expand script
script: function es(edg){ var i,f; for (i=0; i<edg.length; i++) {f=edg.item(i).getFacesOfEdge(); f.setProperty('selected',1);}} var so = moi.geometryDatabase.getSelectedObjects(), sf=so.getFaces(), i; for ( i=0; i<sf.length;i++) es(sf.item(i).getEdges()); es(so.getEdges());
and a shrink script
script: function es(edg){ var i,f; for (i=0; i<edg.length; i++) {f=edg.item(i).getFacesOfEdge(); f.setProperty('selected',0);}} var gd = moi.geometryDatabase; gd.invertSelection(); var so = gd.getSelectedObjects(), sf=so.getFaces(), i; gd.invertSelection(); for ( i=0; i<sf.length;i++) es(sf.item(i).getEdges());
EDITED: 22 Oct 2014 by SMIRNOV
6988.5 In reply to 6988.4
Thanks Max!
@Metin - does that do what you needed?
6988.6
Brilliant! It does exactly what I meant. Many thanks, Max!
— Metin
6988.7
Very very usefull - thank you so much.
6988.8 In reply to 6988.4
Is there a way to select whole islands ?
lets say i have two cubes where I select the front 2 faces and convert it to select the 2 cube`s complete faces
6988.9 In reply to 6988.8
Hi ndrakey, re:
Use "Select All" Ctrl+A to do that - if you have a face or edge sub-object selected, you can then use Ctrl+A / Select All to select all faces or edges of those objects. Once your selection is on a sub-object, select all will see that and select the all the same sub-objects without selecting other top level objects.
So with your cube example, if you have 2 separate cube objects, then you select one front face on each one, press Ctrl+A and then the selection will expand to all the faces on those 2 cubes.
Show messages: All  1  2-9
