Selection grow and shrink script?
6988.1
Does anyone know if there's a script that can expand or contract selections? So if you have one or more faces selected, it would expand the selection with the adjoining faces. I miss that a lot when making selections. I'm used to using it a lot with poly subdivision modeling.
Would be great if that would work on edges and curve/surface control points as well.
Metin
EDITED: 22 Oct 2014 by SEVENSHEAVEN
6988.2 In reply to 6988.1
Hi Metin, it's not really feasible for control points because there is not currently any interface available for scripts to access the control point selection. But I think it may be possible to do something for faces and edges, I will take a look at that a while later on today.
6988.3 In reply to 6988.2
Cool, thanks a lot Michael!
— Metin
metinseven.com — 3D (print) design • animation • artwork • illustration • visualization
6988.4 In reply to 6988.1
Hi Metin,
this is expand script
script: function es(edg){ var i,f; for (i=0; i<edg.length; i++) {f=edg.item(i).getFacesOfEdge(); f.setProperty('selected',1);}} var so = moi.geometryDatabase.getSelectedObjects(), sf=so.getFaces(), i; for ( i=0; i<sf.length;i++) es(sf.item(i).getEdges()); es(so.getEdges());
and a shrink script
script: function es(edg){ var i,f; for (i=0; i<edg.length; i++) {f=edg.item(i).getFacesOfEdge(); f.setProperty('selected',0);}} var gd = moi.geometryDatabase; gd.invertSelection(); var so = gd.getSelectedObjects(), sf=so.getFaces(), i; gd.invertSelection(); for ( i=0; i<sf.length;i++) es(sf.item(i).getEdges());
EDITED: 22 Oct 2014 by SMIRNOV
6988.5 In reply to 6988.4
Thanks Max!
@Metin - does that do what you needed?
6988.6
Brilliant! It does exactly what I meant. Many thanks, Max!
— Metin
6988.7
Very very usefull - thank you so much.
6988.8 In reply to 6988.4
Is there a way to select whole islands ?
lets say i have two cubes where I select the front 2 faces and convert it to select the 2 cube`s complete faces
6988.9 In reply to 6988.8
Hi ndrakey, re:
Use "Select All" Ctrl+A to do that - if you have a face or edge sub-object selected, you can then use Ctrl+A / Select All to select all faces or edges of those objects. Once your selection is on a sub-object, select all will see that and select the all the same sub-objects without selecting other top level objects.
So with your cube example, if you have 2 separate cube objects, then you select one front face on each one, press Ctrl+A and then the selection will expand to all the faces on those 2 cubes.
