MylarBalloon script
All  1-3  4-6
6984.4 In reply to 6984.3
Timely - and impressive!
6984.5 In reply to 6984.2
The mylar balloon profile script is incorrect.
The aspect ratio is too low. The height is too low.
Using an alternate parameterization a curve was generated which created the correct aspect ratio (height over width), (about 0.599).
The error is yet to be found.
So I will delete the script until corrected.
6984.6 In reply to 6984.5
Just uploaded, in message 1, the corrected _Balloon2 script, which is using the simple formula, without cn or dn.
Added a modulus k slider to create other, non-mylar shapes, which are likely not physics based.
For a modulus k = -0.908908557548541+, the origin is (very nearly) crossed, and a revolve results in a solid.
The value was found by using a wide slider with very narrow range -0.9089056 to -0.9089055, then sliding until the z axis is crossed just above or below
the origin. More decimals can be manually added.
For the mylar balloon curve, the aspect ration (Thickness/Diameter) = 0.599+ approximately, is now correct.
Also, geodesics could be calculated for the mylar balloon curve.
Show messages: All  1-3  4-6
