MylarBalloon script
All  1  2-6
Using the MylarBalloon curve as an isotensoid, here is a fake "pumpkin" balloon.
It is just a swept arbitrary arc.
ps The MylarBalloon script does not seem to have quite the correct height. (?)
pps Should have styled it orange.
6984.3 In reply to 6984.2
6984.4 In reply to 6984.3
Timely - and impressive!
6984.5 In reply to 6984.2
The mylar balloon profile script is incorrect.
The aspect ratio is too low. The height is too low.
Using an alternate parameterization a curve was generated which created the correct aspect ratio (height over width), (about 0.599).
The error is yet to be found.
So I will delete the script until corrected.
6984.6 In reply to 6984.5
Just uploaded, in message 1, the corrected _Balloon2 script, which is using the simple formula, without cn or dn.
Added a modulus k slider to create other, non-mylar shapes, which are likely not physics based.
For a modulus k = -0.908908557548541+, the origin is (very nearly) crossed, and a revolve results in a solid.
The value was found by using a wide slider with very narrow range -0.9089056 to -0.9089055, then sliding until the z axis is crossed just above or below
the origin. More decimals can be manually added.
For the mylar balloon curve, the aspect ration (Thickness/Diameter) = 0.599+ approximately, is now correct.
Also, geodesics could be calculated for the mylar balloon curve.
Show messages: All  1  2-6
