"Edit Styles" Button
All  1-4  5-12
6975.5 In reply to 6975.2
Hi Kevin,
> I want to be able to double click the layer name to change its name and colour.
That could be a good one to do when I'm able to spend some time on the Scene Browser in v4 hopefully...
But I'm kind of biased against double-clicks, they can be somewhat awkward when the single click does something else too. It's possible that a left click there will open up a menu with more stuff on it to do to that layer... We'll see... Maybe a right-click there would fit in a bit easier at that time.
6975.6 In reply to 6975.5
Will you be looking at this one also related to the scene browser? http://moi3d.com/forum/index.php?webtag=MOI&msg=4413.11
6975.7 In reply to 6975.6
Hi Danny, I'd kind of forgotten about doing anything about that, but yeah something better to deal with long names would be good to work on as well. I'm kind of generally phobic of tooltips similar to double clicks but it probably does need one like that there... Sometimes those can be rather finicky to set up very well and make sure they dismiss easily and what not so it could end up being quite a bit of work to implement though.
6975.8
nice answers
edward47
6975.9
I use styles constantly, and tend to use a LOT of them. I've no complaints about the thought behind the styles vs layers at all. I do agree it would be nice to be able to change the names directly however (rather than a sub menu and then edit panel).
I also agree that double click method can be a bit hit and miss.
However - would you consider adding CTRL-Click to the style Name field in the same way as you have with the color field to edit color ?
:)Rico
6975.10 In reply to 6975.9
Hi Rico, yeah ctrl+click on the name sounds like a good way to do it. It will be a while before I'll be able to work on any of these kinds of tune-ups though, it will have to wait until the v4 beta period is underway. That will be a while since it's usually better to do some larger structural changes during this in-between time.
6975.11
You see, you say things like "Beta 4 Period" and we're happy to forgive anything. :)
(I'm tinkerbell clapping at the thought)
Outstanding Michael, thank you.
6975.12 In reply to 6975.11
Hi Rico, except don't get too excited quite yet - I was trying to say it will be a while before the v4 betas start up because this time in between major releases tends to be the best time to do major tearing apart and renovation work and that can take a while to do...
Show messages: All  1-4  5-12
