How do you get this into the UI
All  1-4  5-8
6974.5 In reply to 6974.4
Still can't get this to work.This is the error I'm getting now:
Extracting file: C:\Users\Lawrence\Downloads\CustomUI.1.03.win.mac.zip
Extracting to "C:\Program Files (x86)\MoI 3.0 beta Jun-27-2014\"
Use Path: yes Overlay Files: no
Unable to process "objects\".
Severe Error: Not permitted or able to create an output directory.
Any ideas.I'm not really knowledgeable with scripting so I could be making a very basic mistake with my installation but could this be to do with privileges?
6974.6 In reply to 6974.5
Hi hhal - yes that new error is likely related to privileges - there is a Windows security mechanism that by default prevents files under c:\Program Files from being modified.
Please try starting Winzip in this alternate method - right-click it and then choose "Run as administrator". That should launch a session of it with elevated privileges that will allow it to write to c:\Program Files, so hopefully if you do the same thing as before it should work. But please note that you want to change "Overlay Files" to yes because you do want one file to get overwrittten.
Another alternate way is you can unzip it somewhere else like to your desktop and then use the Windows Explorer to copy the files over, Explorer will ask if you want to allow it and then say yes there and tell it to replace the one file that it will ask you about.
Hope this helps,
A couple of screenshots:
Your MoI3 directory may be named differently.
Notice that original CommandBar.htm is, (should be manually), backed up.
(I modified permissions to permit direct unzipping, but this may lower security protection (?))
EDITED: 12 Oct 2014 by BEMFARMER
6974.8 In reply to 6974.7
Thanks Michael and Brian.I've now got the custom UI up and running.In the end I did unzip to the desk top and then move the files over.
Show messages: All  1-4  5-8
