Drawing a corkscrew
All  1  2-16
6970.2 In reply to 6970.1
Is that a helicoid?
Delete the )? from your link.
You can post a picture to the forum.
EDITED: 7 Oct 2014 by BEMFARMER
6970.3 In reply to 6970.2
Ooops. Fixed the link. I'm not sure it's a helicoid exactly, as there should be a central core (ideally) which I just realized isn't part of a plain helix, so I'll have to add that. If necessary, I guess I can omit it, but I need to preserve the taper.
6970.4 In reply to 6970.3
I tried a Loft with centerline and tapered helix. Looks good.
The ISO's look good.
Make a regular helix and a tapered helix, and centerline.
Maybe bolean with a skinny cylinder at the center, and round tip?
6970.5 In reply to 6970.1
I think Brian's method is something like the attached file, 2 curves and then do a loft between them. Is that close to what you are looking for?
6970.6 In reply to 6970.1
Another possibility is to use the Transform > Deform > Flow command to introduce tapering. That's where you'll surround the object with a cylindrical looking revolve (with a few more control points in it than a regular cylinder), and then make a second copy of that revolve edited to be tapered. Then select the object to be deformed, run Transform > Deform > Flow, select the cylinder surrounding it as the base surface, and the tapered one as the target surface. That will generate a tapering effect as in the attached file, it will allow you to produce the tapering in a non-uniform way.
Some of these kinds of things that squash surfaces down to some collapsed shape can somewhat easily generate a self-intersecting surface which then won't work very well with boolean calculations after that, that's something to keep in mind if you are going to try to intersect the surface in some later on step.
6970.7 In reply to 6970.6
Thanks for the tips, guys. I'm on my iPad at the moment, so I'll check these out tomorrow and let you know.
Btw, Michael, I'm not getting e-mail notifications of these postings even thought that's what I've requested in my profile. FYI.
Karl
6970.8 In reply to 6970.7
Hi Karl,
Do you have it enabled under Options > Email & Privacy > "Notify by email of posts to me" ?
Do you get any e-mails at all about replies?
Also double check that you've got your correct e-mail address set up.
But it's possible that part of the forum is just not working...
6970.9 In reply to 6970.8
Yes, yes, and yes. Do you know if it's working for anyone else?
6970.10 In reply to 6970.5
Brian's approach is exactly what I was looking for (my version below). So simple when you know how, and are using MoI. Great product, Michael.
6970.11 In reply to 6970.9
Hi Karl, re: forum e-mail notifications
I'm not really sure if it is working for anyone else or not... I'll turn it on for a while myself and see if it works for me.
6970.12 In reply to 6970.11
I also haven't received email notifications lately, despite several new messages in subscribed threads. I thought it was caused by changing my email address a while ago.
metinseven.com — 3D (print) modeling • animation • artwork • design • illustration • visualization
6970.13 In reply to 6970.10
Played around a little with the corkscrew.
After saving and reloading, it became a solid.
EDITED: 2 Apr 2015 by BEMFARMER
6970.14 In reply to 6970.11
Just a quick note: I'm receiving thread subscription email notifications again, thanks Michael!
6970.15 In reply to 6970.14
@Metin,
Hmmm, I did not do anything to fix it so I'm not sure why it wasn't working before...
6970.16 In reply to 6970.15
The email notification behaviour seems unpredictable. Sometimes it works, other times I discover that there are already multiple replies to a subscribed topic on the forum.
Well, it's not very important to me. This pushes me to become a more active forum participant. ㋡
— Metin
metinseven.com — 3D (print) design • animation • artwork • illustration • visualization
Show messages: All  1  2-16
