MoI and Yosemite fails
 1-19  20-26
6967.20 In reply to 6967.19
Although the new Window appears I noticed a rotating gear symbol in the task bar and when I click on it the info shown below appears
The gear symbol keeps spinning until I close MoI.
Martin
6967.21
Yesterday, I had a friend over with his new MacPro running Yosemite. He was still running the last v3 beta, and it was only now when he noticed the viewports' background and grid colors were a bit odd. It looked almost inverted, quite a bit darker gray, and you could barely distinguish the origin axis compared to the grid (lines were brighter than the background).
Object display was OK though, as was the look of the rest of the UI.
We made sure it grid settings were reset to their defaults, but the problem remained when doing a screen-by-screen comparison with my display.
Did anyone else notice this? It probably can be remedied by custom color settings, but it was kind of odd to see.
6967.22
Martin, i used to get that spinning gear in maverics as well. You can safely click on it and hit the little red (x) next to the script. That will get rid of the gear menu.
Well, it appears that NewWindow not working at all affects only me. I'll check it later in more detail.
Thanks for the replies.
Dinos
6967.23 In reply to 6967.17
Hi dinos,
also for me the "New window" didn't work anymore with moiv3 and yosemit...
But i just tried the setting michael described before (to use system x11 instead of the build in wineskin) and now i can work with different windows again. Just open moi several times and you have several moi windows. its even faster window opening than with wineskin...
6967.24
Hi r2d3,
thanks! The workaround you describe works on my system as well.
I'll leave it like this until wineskin is updated to resolve this issue.
Dinos
6967.25 In reply to 6967.24
Hi dinos,
thats nice :-)
me too, i wait until wineskin offers a solution and then i will wait for a real MoI OS X App...
6967.26 In reply to 6967.4
Yes, it is working. thank you, thank toy, thank yoooo
Show messages:  1-19  20-26
