DXF in Moi
All  1  2-4
6954.2 In reply to 6954.1
Hi mike, when you saved out to AI format, did you use the scale option for "Fit to page" or "Preserve units" ?
If you set "Preserve units" and the coordinates of the resulting curves are a far distance away from the origin, it's possible that they would just not show up in Illustrator because Illustrator only works with objects with a fairly limited coordinate range.
If that's not the case can you please e-mail me (moi@moi3d.com) both your DXF file and the generated AI file so I can take a look at them?
6954.3 In reply to 6954.2
I did it as you wrote here. I thought fitting the page might scale something.
6954.4 In reply to 6954.3
Alls well, your explanation was spot on.
Show messages: All  1  2-4
