Log Spiral
 1-4  5-24  25-29
6951.25 In reply to 6951.23
The PushButton in LogSpiral7 looks good Brian.
> I should rename the PushButton "Restore Golden Spiral"
I'd suggest that it simply say "Golden Spiral" as it is now a clear UI element whose function is to reset the Grow_Shrink to the proper value to produce the Golden Spiral.
On edit:
The help text "To revert to the default Golden Spiral, Click on the box: Click for Golden Spiral." might be simplified to "Click the Golden Spiral button to revert to the Golden Spiral."
--Larry
EDITED: 19 Jul 2022 by FAHNOE
Version 8 of LogSpiral.
As per Larry, renamed pushbutton and changed help text.
Changed color of pushbutton text to html darkgoldenrod.
EDITED: 7 Aug 2022 by BEMFARMER
6951.27 In reply to 6951.26
Looks good Brian & again, a neat script!
--Larry
"Final" update to LogSpiral scripts. This would be version9, but I removed the version number.
Got rid of darkgoldenrod color.
Added elastica style centerPlane1 Frame, so the LogSpiral will form in any of the seven MoI Views, parallel to it's axis grid, including previously set CPlane Frame.
If user has an old LogSpiral script in a commands folder that the user wishes to keep, suggest renaming it LogSpiralOLD.
Thought about getting rid of underline, but did not.
6951.29 In reply to 6951.28
Looks good Brian, neat to be able to use any view as well, thanks!
--Larry
Show messages:  1-4  5-24  25-29
