spring script
All  1-2  3-5
6946.3 In reply to 6946.1
The variable pitch helix script may help.
http://moi3d.com/forum/index.php?webtag=MOI&msg=6697.1
http://www.zwsoft.com/zwcad_forum/thread-2980-1-1.html
A google of "variable pitch helix equation" yields information on springs.
Sweep the helix with a circle.
6946.4
thanks for the pointers. I know about the helix function, its just that I am sure i used to use a spring script whereby i simply gave it some parameters i.e. length, dia. spring thickness and number of turns and it was done for you. Maybe it was just a dream . . .would be anise function in V4 in the solids sections . .
Matt
6946.5 In reply to 6946.4
Hi Matt, there is not currently any special spring solid plug-in that I know of, but there is a "Pipe" plug-in where it will make a tube around your curve, basically doing the same job as drawing a circle and doing a sweep but automating the circle drawing step for you.
Some info on that here:
http://kyticka.webzdarma.cz/3d/moi/#Pipe
Show messages: All  1-2  3-5
