Sketchup export
6932.1
Hi, I would like to ask, when I export some object into sketchup is that possible to convert named objects into Sketchup Components? This feature would be really convenient.
6932.2 In reply to 6932.1
Hi Andras - I'd like to do components in the future but I think it would be a better match to first implement "blocks" or "instances" in MoI first and then try to have those come over as components rather than trying to map just basic named objects into components in SketchUp.
Maybe I don't fully understand how SketchUp components work, are they just a name label for an object, or are they instances where many clones of a certain template object can be inserted and then modified by changing their base template?
Till now export your object in 3ds format from Moi! (if you have more than object!
Import them in Sketchup
Explode them one time if you have more than one object!
With names or without name from Moi they will arrive in Sketchup with definition name obj0, obj1, obj2 etc...
6932.4 In reply to 6932.2
in sketchup "groups" are named objects and "components" are instances.
They are quite powerful.
If you edit one component (double clicking on it) and save it all other copies are updated. You can "save as" a component in an external file; "reload" a component from an external file (changing all the instances); "make unique" a component so it is detached from all the other copies. You can also add or move sub-components or sub-group using the "Outliner" tool.
In Sketchup pro 2014 it is also available a "Classifier" tool: you can attach info to a component for exchanging data (not only geometry) with other 3D BIM software or for extracting data and to generate reports.
Thank you for your great work!
-Giovanni
6932.5
Eventually 3ds export works as I expected thanks for the tip, So all cubes that I made in moi3d are imported as groups in sketchup. That's great.
